esri.bundle problem since 3.4
1988
06-05-2013 05:44 AM
TomasNovotny
I use my own strings in esri.bundle.toolbars.draw to localize map drawing tooltips (to Czech). This seems to stopped working in version 3.4+. Did I miss something in changelog or is there some easy workaround?
Thank you,
Tomas
KellyHutchins
Esri Notable Contributor
Hi Tomas,
I ran a quick test using the steps below and the new tips worked for me in Chrome but not Firefox. Restarted firefox with add-ins disabled (Firefox > Help > Restart with addins disabled) and then it worked for me there too.
1. Load this in chrome: http://developers.arcgis.com/en/javascript/samples/toolbar_draw/
2. Set a breakpoint at line #1 in init. Refresh the page.
3. Execute this in console: esri.bundle.toolbars.draw.addPoint = "Add new location"
4. Continue execution
5. Click "Point". Tooltip shows "Add new location"
Are you able to reproduce the issue in multiple browsers?
TomasNovotny
Hi Kelly,
Thank you for quick repsonse. I've tried your test and found out this:
working:
esri.bundle.toolbars.draw.addMultipoint = 'localized text';
working:
esri.bundle.toolbars.draw = { addMultipoint: 'localized text'};
NOT working:
esri.bundle.toolbars = {draw: { addMultipoint: 'localized text'}};
As you can see, setting custom properties on higher level then esri.bundle.toolbars.draw doesn't work (and does in version 3.3). Obviously I can live with it but I'm curious what the problem is.
Tomas
KellyHutchins
I ran a quick test and was able to set new strings for esri.bundle.toolbars. Can you test this code and let me know if it works for you?
http://jsfiddle.net/C63WY/
TomasNovotny
This works. Well, the difference is in using dojo.mixin and not setting esri.bundle properties directly. Still not sure why it matters, sounds a bit like undocumented feature brought in 3.4.
Anyway, thank you very much for help!
Tomas
CarlosMacias
yes it looks like the properties can't be set directly.
I tried redefining the property with code similar to this thread using this jsfiddle but didn't work.
is there an example for this using AMD?
