esri base maps with google maps apis
2024
6
06-28-2011 05:29 AM
AlessioDi_Lorenzo
Hi I'm using the Google Maps API extension, I would like to select also the ESRI basemaps as alternative to the standard Google basemaps. Is it possible?
Thanks
derekswingley1
How about moving to the full ArcGIS API for JavaScript and using this sample to get Google Maps in your JS app:  http://gmaps-utility-gis.googlecode.com/svn/tags/gmapslayer/1.0/docs/examples.html
AlessioDi_Lorenzo
I have already developed a gis template with many functions with the google maps extender. Now it's too complicated to switch on the other apis only for the baselayers 🙂
HemingZhu
I don't think you can use basemap gallery on Google Map API. But you can use ESRI base map as ArcGIS Server cached map and add it on the google maps. There are plenty sample on: http://help.arcgis.com/en/webapi/javascript/gmaps/help/google_start.htm
ShaningYu
Honored Contributor
swingley:
I tried the script but the google maps do not display.  I post a thread at http://forums.arcgis.com/threads/34799-Google-Maps-Not-Display?highlight=google+maps.  Do you know how to fix it?   Thanks.
Shaning
ShaningYu
Honored Contributor
I have the same goal as digy79.  Looking at ESRI's sample code, it is possible.  However, when I loaded the code and run it loacally, I got problem.  In my test, the associated js file was called correctly.  Hopefully ESRI can provide a good answer for it.
StephenLead
Honored Contributor
This is the best of both worlds - the attractiveness of Google's base maps, with the functionality of the ArcGIS JS API. Win-win!
