Error when removing some ESRI basemaps from the basemapGallery
1570
11-14-2016 09:37 AM
ChristopherJohnson1
I am using the ArcGIS JS API 3.16 and I am attempting to remove some of the ESRI basemaps from the basemapGallery.  Some of the items are being removed, but I am encountering an issue with the last item not being removed (when the index gets to 10).  The error is
"esri.dijit.BasemapGallery: could not find group for basemaps.".
Any ideas?
The code is attached/below.
Thanks...Chris
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title>Basemap gallery</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
  <style>
    html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    #map{
      padding:0;
  </style>
  <script src="https://js.arcgis.com/3.18/"></script>
  <script>
    var map;
    require([
      "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
      "dojo/parser",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      Map, BasemapGallery, arcgisUtils,
      parser
      parser.parse();
      map = new Map("map", {
        basemap: "topo",
        center: [-105.255, 40.022],
        zoom: 13
      //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
      var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: true,
        map: map
      }, "basemapGallery");
      basemapGallery.startup();
      basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
      basemapGallery.on("load", function()
               var tot = basemapGallery.basemaps.length;
               for (var cnt = 0; cnt < tot; cnt++)
                    if (basemapGallery.basemaps[cnt].title === "Oceans" || basemapGallery.basemaps[cnt].title === "OpenStreetMap" || basemapGallery.basemaps[cnt].title === "USGS National Map" || basemapGallery.basemaps[cnt].title === "USA Topo Maps")
                         console.log("Removing..." + basemapGallery.basemaps[cnt].title);
                         basemapGallery.remove(basemapGallery.basemaps[cnt].id);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer"
       data-dojo-props="design:'headline', gutters:false"
       style="width:100%;height:100%;margin:0;">
    <div id="map"
         data-dojo-type="dijit/layout/ContentPane"
         data-dojo-props="region:'center'"
         style="padding:0;">
      <div style="position:absolute; right:20px; top:10px; z-Index:999;">
        <div data-dojo-type="dijit/TitlePane"
             data-dojo-props="title:'Switch Basemap', closable:false, open:false">
          <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
            <div id="basemapGallery"></div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
Tags (1)
RobertScheitlin__GISP
Chris,
   When removing items from the array you are looping through you always need to loop through the array in reverse:
            basemapGallery.on("load", function() {
                for (var cnt = tot - 1; cnt >= 0; cnt--) {
                        "USA Topo Maps") {
Chris,
                        "USA Topo Maps") {
ChristopherJohnson1
Thanks, Robert!  I wondered about that, and even tried it, but I guess my syntax was wrong.  Anyways, thanks again!!!
- Chris
