Error typescript CSS
2259
02-22-2024 06:29 AM
tnascimento
After I upgraded to version of arcgis/core to 4.28.10 I started receiving a compilation error related to some grayscale function missing $color
^^^^^^^^^^^ invocation
┌──> sass:color
1 │ @function grayscale($color) {
│ ━━━━━━━━━━━━━━━━━ declaration
node_modules/@arcgis/core/assets/esri/themes/dark/main.css 1:496278 root stylesheet
webpack compiled with 1 error
I'm importing the dark theme in my react component as
@import "@arcgis/core/assets/esri/themes/dark/main.css";
Anyone knows how this could be fixed?
ReneRubalcava
Esri Frequent Contributor
Empty is just treated like 100%. Are you importing with the .css extension in your sass file? I would import the css in your JavaScript file rather than the sass file so it doesn't try to process it.
ReneRubalcava
Do you have a basic report project on GitHub to look at? Importing the css file shouldn't invoke the sass files, so it suggests something else in your build is referencing them.
tnascimento
I don't have a public repo for this project. I checked and is using default CRAS without any transformation or building steps for sass.
The only thing is when adding the @import "@arcgis/core/assets/esri/themes/dark/main.css"; in a scss file it brokes the build, but if I remove it built but without the styles needed.
tnascimento
After some more digging, in the class 'esri-elevation-profile-legend-item--disabled',  there's a missing parameter in
filter: grayscale()
ReneRubalcava
