Error: Tried to register widget with id==legendDiv but that id is already registered
5086
8
12-03-2012 05:35 AM
CraigMcDade
I'm getting:
when loading my map. I've searched around and it seems to be an issue with a few other widgets as well. Can anybody recommend a good work around?
JeffPace
you are calling addLayers twice.  Remember this is all asynchronous.
You call add layers, then define a legend in the callback.  Likely after the legend is defined, the event actually occurs, triggering it.
You then call addLayers again, which triggers the callback again, which tries to create a second legend.
derekswingley1
This happens when you try to create multiple widgets with the same id. Are you trying to create a new legend without first destroying a previous one you created?
CraigMcDade
No. My only instances for legend is once in the JS:
//Add the Legend
          legendLayers.push({
              layer: layer,
              title: ''
          dojo.connect(map, 'onLayersAddResult', function (results) {
              var legend = new esri.dijit.Legend({
                  map: map,
                  layerInfos: legendLayers
              }, "legendDiv");
              legend.startup();
          map.addLayers([layer]);
          if (layer.loaded) {
              buildLayerList(layer);
          } else {
              dojo.connect(layer, "onLoad", buildLayerList);
and once in the HTML:
<div dojoType="dijit.TitlePane" title="Legend" closable="false"  open="false" style="float:right;">
     <div dojoType="dijit.layout.ContentPane" style="width:180px; overflow:auto;">
     <span id="legendDiv"></span>
     </div>
        </div>
JeffPace
although i might be reading it wrong, it looks like you are CREATING a legend on each layer add.  So it would work the first time, but on the second layer it is trying to create a second legend.
derekswingley1
How many times is onLayersAddResult firing?
Can you post a full repro case? We'll be able to get to the bottom of this faster if you post code that reproduces the error.
CraigMcDade
This link should work in IE9. As always, I appreciate your help.
JeffPace
CraigMcDade
Thanks Jeff. Totally overlooked that. This answer actually solves my basemap gallery issue as well.
I appreciate the help.
JeffPace
glad to help!
