Error: ?????????????? (null): Unable to complete operation.
1292
12-26-2012 08:27 PM
tongwenhuan
...],g=this.graphics;while(g.length>0){this.remove(g[0]);}if(!_771){this.onGraphics...
[ATTACH=CONFIG]20207[/ATTACH]
my page is code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <title>Simple Map</title>
    <link rel="stylesheet" type="text/css" href="http://127.0.0.1/arcgis_js_api/library/3.2/jsapi/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript" src="http://127.0.0.1/arcgis_js_api/library/3.2/jsapi"></script>
    <style>
        html,body{height:100%;width:100%;margin:0;padding: 0;overflow:hidden;}
    </style>
    <script type="text/javascript">
      dojo.require("esri.map");
  dojo.require("esri.layers.FeatureLayer");
      function init() {
        var myMap = new esri.Map("mapDiv");
        //note that if you do not have public Internet access then you will need to point this url to your own locally accessible cached service.
        var myTiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://127.0.0.1/ArcGIS/rest/services/hseds2012/MapServer");
        myMap.addLayer(myTiledMapServiceLayer);
var featureLayer = new esri.layers.FeatureLayer("http://127.0.0.1/ArcGIS/rest/services/sde/FeatureServer/0", {
            outFields: ["*"],
            mode: esri.layers.FeatureLayer.MODE_SNAPSHOT
          myMap.addLayer(featureLayer);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
    <div id="mapDiv" style="width:900px; height:600px; border:1px solid #000;"></div>
  </body>
</html>
i found when add featureLayer with firefox ,open this errors.
JakeSkinner
Esri Esteemed Contributor
Hi Tong,
Are you running ArcGIS for Server 10.1 Service Pack 1?  You may be experiencing a bug:
NIM086349:  Alternate Query (Get) requests fail in Version 10.1 SP1.
If you refresh the web page, do you receive the same error?
Jay_Gregory
This this bug does affect the JS API FeatureLayer? Is there any workaround currently, or prediction of when it might be fixed?
I had just recently posted this to the forums.
Thanks!
Jay
