Error: an unknown error occurred while detecting CORS support
2775
02-13-2014 12:51 PM
ZachLiu1
I got this message for my application.
Does anyone know what this means?
It seems not to bother the application.
ManishkumarPatel
Cross-Origin Resource Sharing (CORS) allows web applications to bypass a browser's same origin policy. When both the web server and browser support CORS, a proxy  is not required to do cross-domain requests. This both simplifies  application development and potentially provides a performance boost.  Development is simplified because it is no longer necessary to maintain a  proxy page on your server. The performance boost comes from accessing a  resource directly rather than sending a request back to your server,  which then requests the specified URL and returns the result.
For further details please find the below link:
https://developers.arcgis.com/javascript/jshelp/inside_defaults.html
[h=4]Refer to the below:
esriConfig.defaults.io.corsDetection
esriConfig.defaults.io.corsEnabledServers
Hope this helps.
Best Regards,
Manish Patel
ManishkumarPatel
Hope this helps.
Best Regards,
Manish Patel
ZachLiu1
Thanks for clarifying this.
I am using a proxy page, so now basically I set esriConfig.defaults.io.corsDetection to false.
