Entire application not working on Internet Explorer
1339
11-10-2012 04:44 PM
SmaranHarihar
Hey guys,
My application works fine on Firefox and Chrome but for some reason it is not working in Internet Explorer. Nothing appears except for the header on Internet Explorer. The version I am using is IE8.
This is my application.
Any idea what I need to correct?
BillDaigle
You have a trailing comma in your legend parameter on line 31 of tp_dock.html.  IE is more susceptible to trailing commas.
     map.addLayer(statesLyr);
        dojo.connect(map,'onLayersAddResult',function(results){
         //add the legend
          var legend = new esri.dijit.Legend({
            map:map,
            layerInfos:legendLayers,
          },"legendDiv");
      legend.startup();
If you're using Aptana, try enabling JSLint validation.  It will help you track down a lot of simple issues like that.
DavideLimosani
Too se errors in IE8:
F12 --> open developer tools
click con Script and then console
In the console you will read the error indicated by bdaigle
Davide
JeffJacobson
There is also a JSLint extension for Visual Studio available through NuGet.
SmaranHarihar
Davide
Thanks for the response guys.
Why does the IE give
Object doesn't support this property or method
for,
gpint = dojo.byId("gpTool");
and
ddMxd = dijit.byId('ddMxd');
