Enter parcel number and zoom to result
2837
07-02-2013 10:54 AM
MichaelMachado
Hi, like many others, I'm just starting to learn javascript.  I've tried some of the samples but still not finding much success.  I have a map service I'm pointing to and a geocoder service.  I would like to be able to enter the parcel number and be able to zoom to it on the map.  Any help would be most appreciated.  Thanks
ShaunWeston
You could probably use either the geocode or map service to zoom to the parcel. You could probably use a findtask to do the search like this sample - https://developers.arcgis.com/en/javascript/jssamples/find_map.html
a
nd then just add another bit into zoom to the parcel extent
So maybe if you took that sample and pointed it at your map service, it might be a good start.
MichaelMachado
Thanks, I'll give it a try.
MustafaOgurlu
Hi RuthAnne,
I wrote the code for you. I hope it will be useful for you.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Find Task</title>
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; overflow:hidden; }
      body { font-size: 0.9em; font-family: Geneva, Arial, Helvetica, sans-serif;
      } .details { font-weight: bold; } #grid { border:
      1px solid #333;}
    </style>
    <script>        var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
    <script>
        dojo.require("dojox.grid.DataGrid");
        dojo.require("dojo.data.ItemFileReadStore");
        dojo.require("esri.map");
        dojo.require("esri.tasks.find");
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        var findTask, findParams, map;
        function init() {
            var initExtent = new esri.geometry.Extent({ "xmin": -125.0552, "ymin": 38.7130, "xmax": -70.2156, "ymax": 48.4081, "spatialReference": { "wkid": 4326} });
            map = new esri.Map("map", { extent: initExtent });
            var censusMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer", {
            map.addLayer(censusMapLayer);
            //create find task with url to map service
            findTask = new esri.tasks.FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer");
            //create find parameters and define known values
            findParams = new esri.tasks.FindParameters();
            findParams.returnGeometry = true;
            findParams.layerIds = [0, 1, 2];
            findParams.searchFields = ["CITY_NAME", "NAME", "SYSTEM", "STATE_ABBR", "STATE_NAME"];
            dojo.connect(grid, "onRowClick", onRowClickHandler1);
        function execute(searchText) {
            //set the search text to find parameters
            findParams.searchText = searchText;
            findTask.execute(findParams, showResults);
        function showResults(results) {
            //symbology for graphics
            var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25]));
            var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 1);
            var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NONE, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));
            //find results return an array of findResult.
            map.graphics.clear();
            var dataForGrid = [];
            //Build an array of attribute information and add each found graphic to the map
            dojo.forEach(results, function (result) {
                var graphic = result.feature;
                //dataForGrid.push([result.layerName, result.foundFieldName, result.value]);
                switch (graphic.geometry.type) {
                    case "point":
                        dataForGrid.push([result.layerName, result.foundFieldName, result.value.toString(), result.feature.geometry.x, result.feature.geometry.y]);
                        graphic.setSymbol(markerSymbol);
                        break;
                    case "polyline":
                        dataForGrid.push([result.layerName, result.foundFieldName, result.value.toString(), ((result.feature.geometry.getExtent().xmin + result.feature.geometry.getExtent().xmax) / 2), ((result.feature.geometry.getExtent().ymin + result.feature.geometry.getExtent().ymax) / 2)]);
                        graphic.setSymbol(lineSymbol);
                        break;
                    case "polygon":
                        graphic.setSymbol(polygonSymbol);
                        break;
                map.graphics.add(graphic);
            var data = {
                items: dataForGrid
            var store = new dojo.data.ItemFileReadStore({
                data: data
            grid.setStore(store);
        //Zoom to the parcel when the user clicks a row
        function onRowClickHandler1(evt) {
            var gr = grid.getItem(evt.rowIndex);
                var x = parseFloat(gr[3][0]);
                var y = parseFloat(gr[4][0]);
                if ((x.toString() != "NaN") || (y.toString() != "NaN")) {
                    var initExtent = new esri.geometry.Extent({ "xmin": x - 0.1, "ymin": y - 0.1, "xmax": x + 0.1, "ymax": y + 0.1, "spatialReference": map.spatialReference });
                    map.graphics.add(new esri.Graphic(new esri.geometry.Point(x, y, map.spatialReference), new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 8, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.3]))))
                    map.setExtent(initExtent);
        dojo.ready(init);
    </script>
  </head>
  <body class="claro">
   <div data-dojo-type="dijit.layout.BorderContainer" style="width:100%;height:100%;margin:0" data-dojo-props="design:'headline',gutters:true">
    <div class="details" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="region:'top'" style="height:30px;">
      Find State/City/River:
      <input type="text" id="searchText" value="KS" />
      <input type="button" value="Find" onclick="execute(dojo.byId('searchText').value);"/>
    </div>
    <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" style="border:1px solid #000;"></div>
    <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width:300px;">
    <!--Refer to field by the position id, since the data doesn't have field
    names-->
    <table data-dojo-type="dojox.grid.DataGrid" jsid="grid" id="grid" >
      <thead>
        <tr>
          <th field="0" >
            Layer Name
          </th>
          <th field="1" >
            Field Name
          </th>
          <th field="2" >
            Value
          </th>
        </tr>
      </thead>
    </table>
    </div>
   </div>
  </body>
</html>
MichaelMachado
Thank you.  Had to work on another project today and finally had some time to check the forum.  I'll give it a try first thing in the mornign.
MichaelMachado
Hello,
Thank you again, I was able to get this to show up correctly with the topo background.  However, it doesn't zoom to the parcel number/parcel.  Do I need to add the map service with the parcel layer identified like this?  (http://merced-gis/ArcGIS/rest/services/Web_Applications/Parcel_Search/MapServer/7).  If so, do I add it before or after the url of the geocoder?  Thanks for your help.
