Embed token as URL parameter in QueryTask
1961
05-08-2013 07:16 AM
JeffPace
I have a query that is hitting a secure service.  My app is already validated and has a token.  I would like to append the token in the query so when i execute the task it works.
Bit I cant seeem to
If i add it as
var q = new esri.tasks.Query();                           q.maxAllowableOffset = 0;                 q.returnGeometry = true;                 q.token = mytoken;
it just gets ignored.
any ideas?
thanks
JeffPace
got it using esri.setRequestPreCallback
JeffPace
DavidColey
MVP Frequent Contributor
Hi Jeff-
I'm working with a FeatureLayer for Sarasota County Evacuation Zones app, and am curious about the maxAllowableOffset parameter at 3.6.  I'm having some performance issues with the surge layer, and I believe that at 3.6 this value is auto-calculated upon an extent change.  Is there a better way to set it explicitly?
Thanks
David
