Eliminate the upper toolbar of InfoWindow
7242
8
02-01-2015 12:06 PM
MiriEshel
I'm trying to eliminate the upper toolbar of infoWindow that contains maximize and close buttons.
I want to do it because I use Editor.AttributeInspector and I want the user to use either the OK button or Delete Button.
I don't want the user to click on the close
Here is the code I wrote:
initEditor: function() {
        this._defaultStartStr = esriBundle.toolbars.draw.start;
        esriBundle.toolbars.draw.start = esriBundle.toolbars.draw.start +
          "<br/>" + "(" + this.nls.pressStr + "<b>" +
          this.nls.ctrlStr + "</b> " + this.nls.snapStr + ")";
        this._defaultAddPointStr = esriBundle.toolbars.draw.addPoint;
        esriBundle.toolbars.draw.addPoint = esriBundle.toolbars.draw.addPoint +
        var json = this.config.editor;
        var settings = {};
        for (var attr in json) {
          settings[attr] = json[attr];
        settings.layerInfos = this.layers;
        settings.map = this.map;
        var params = {
          settings: settings
        if (!this.editDiv) {
          this.editDiv = html.create("div", {
            style: {
              width: "100%",
              height: "100%"
          html.place(this.editDiv, this.domNode);
        this.editor = new Editor(params, this.editDiv);
        this.editor.startup();
        var feature;
        var attInspector = this.editor.attributeInspector;
        var theMap = this.editor.settings.map;
       theMap.infoWindow._sizers[0].height = 0;
var saveButton = new dijit.form.Button({label:"OK","class":"saveButton"});
        dojo.place(saveButton.domNode, attInspector.deleteBtn.domNode, "before");
saveButton.on("click", function() {
  if (feature == null)
   alert("Please enter values");
  else {
   if (feature.attributes["name"] != null) {
    feature.attributes["date1"] = Date.now();
    theMap.infoWindow.hide();
   } else {
      alert("Name is a required field");
attInspector.on("attribute-change", function(evt) {
   feature = evt.feature;
theMap.infoWindow.resize(350, 700);
        this.resize();
Thanks a lot,
Miri
RobertScheitlin__GISP
Miri,
  OK that can be handled then.
In the client\stemapp\widgets\Edit\widget.js
Make these changes:
add these vars to the widget
      _onshowinfowin: null,
      _mapInfoWin: null,
Change the Open function to this:
      onOpen: function() {
        this.layers = [];
        this.disableWebMapPopup();
        this.getLayers();
        this.initEditor();
        this._onshowinfowin = on(this.map.infoWindow, "show", this.showInfoWin);
Add this new function
      showInfoWin: function(evt){
        this._mapInfoWin = this.target;
        if(html.hasClass(evt.target._contentPane.firstChild,'esriAttributeInspector')){
          query(".titleButton.close", this.target).style('display', 'none');
          query(".titleButton.maximize", this.target).style('display', 'none');
        }else{
          query(".titleButton.close", this.target).style('display', null);
          query(".titleButton.maximize", this.target).style('display', null);
Change the close function to this:
      onClose: function() {
        this.enableWebMapPopup();
        if (this.editor) {
          this.editor.destroy();
        this.layers = [];
        this.editor = null;
          style: {
            width: "100%",
            height: "100%"
        esriBundle.toolbars.draw.start = this._defaultStartStr;
        esriBundle.toolbars.draw.addPoint = this._defaultAddPointStr;
        this._onshowinfowin.remove();
        query(".titleButton.close", this._mapInfoWin).style('display', null);
        query(".titleButton.maximize", this._mapInfoWin).style('display', null);
Miri,
  You could simply hide the buttons in the css:
      .esriPopup .titleButton.close,
      .esriPopup .titleButton.maximize{
        display: none;
MiriEshel
Hi Robert,
Thanks. Changing the CSS is a good idea and works wonderful.
One more question if I may.....
I take the basic ed_simpletoolbar.html from the sample code and change its attributeInspector. I want to add a button but also limit the number of fields displayed. I'm doing it by adding the lines:
myEditor.startup();
         var attInspector = myEditor.attributeInspector;
          var saveButton = new dijit.form.Button({label:"שלח","class":"saveButton"});
          var layerInfos = [
       'featureLayer': attInspector.layerInfos[0].featureLayer, //waterBodies
       'showAttachments': true,
       'showDeleteButton': true,
       'isEditable': true,
       'fieldInfos': [
     {'fieldName': 'Elevation', 'isEditable': true, 'tooltip': 'Elev'},
     {'fieldName': 'Reach Code', 'isEditable': true, 'tooltip': 'Code'}
attInspector.layerInfos = layerInfos;
myEditor.attInspector = attInspector;
When I put a breakpoint, I see that it behave like I expected but when the infoWindow opens, it shows all the fields.
Why? What do I do wrong?
Miri
MiriEshel
Hi Robert,
The problem of hiding the buttons in the CSS is that it hides them also for Identify windows, not only the Editor staff and this is not what I want....
I prefer to eliminate them only when the Editor is running.
Thanks a lot,
miri
Miri,
Make these changes:
      _mapInfoWin: null,
        this.layers = [];
        this.getLayers();
        this.initEditor();
        }else{
        if (this.editor) {
        this.layers = [];
        this.editor = null;
          style: {
            width: "100%",
            height: "100%"
MiriEshel
Hi Robert,
Thank you. I will check it.
Is this the way to cause the infoWindow to open always on the lest side of the map? That's what the client wants....
Thanks again,
Miri
Miri,
   My last post was to answer your original question with your added concern.
MiriEshel
Hi Robert,
It works great. Thanks.
Miri
abhimanyugupta
i need to add button in toolbar do you have any solution
