Elevation profile from multiple layers
650
08-05-2024 04:52 AM
ImreZuber
We have multiple (generally two) layers set for the Elevation widget as ground layer collection. There is only one ground profile displayed. We already figured out that it is possible to mix multiple layers, if one of the layers does not return any elevation value (e.g. outside of a country borders) the other one will be used for that part of the profile line.
Yet the documentation does not state how the profile is calculated if both layers do provide correct elevation results. Is it based on the order of the layers in the ground collection? So if the first layer has a value, the second layer won't be queried at all? We'd need an exact answer for this kind of situation.
Thanks!
