Between version 4.16 and version 4.22 of the API, on the FeatureLayer's "edits" event, the "target" property (hence target.url) is no longer exposed/returned, which we use to perform a check, i.e., figuring out on which layer to go and update the an other field with the WebService 'Update_Features'.
Any images of code...
and
there's an other way to create a feature with an hidden field forced to a specific value?
thanks
Solved! Go to Solution.
You can use bind in order to maintain a reference to your layer. For example:
l_FeatureLayer.on("edits", otRilievi_Object.rilievi_edits_complete.bind(otRilievi_Object, l_FeatureLayer));...and elsewhere...
this.rilievi_edits_complete = function(target, p_Features) {
//target is now a reference to the layer being edited
This is a compate beteen api 4.15 with target property and 4.22 without.
I've not found info about deprecation of target....
Was useful for us.
Thanks
Thank you very much Joel,
your suggestion was perfect!!!
