Editor widget 4.22 force value attribute on creation
1455
05-26-2022 02:23 PM
DamianoMontrasio
Between version 4.16 and version 4.22 of the API, on the FeatureLayer's "edits" event, the "target" property (hence target.url) is no longer exposed/returned, which we use to perform a check, i.e., figuring out on which layer to go and update the an other field with the WebService 'Update_Features'.
Any images of code...
and
there's an other way to create a feature with an hidden field forced to a specific value?
thanks
JoelBennett
MVP Regular Contributor
You can use bind in order to maintain a reference to your layer. For example:
l_FeatureLayer.on("edits", otRilievi_Object.rilievi_edits_complete.bind(otRilievi_Object, l_FeatureLayer));
...and elsewhere...
this.rilievi_edits_complete = function(target, p_Features) {
	//target is now a reference to the layer being edited
DamianoMontrasio
This is a compate beteen api 4.15 with target property and 4.22 without.
I've not found info about deprecation of target....
Was useful for us.
JoelBennett
...and elsewhere...
DamianoMontrasio
Thank you very much Joel,
your suggestion was perfect!!!
