Editor events
1331
12-08-2022 11:53 PM
RemiBecheru
How to trigger an event when that exclamation mark is added to the map ?
(view in My Videos)
ReneRubalcava
Esri Frequent Contributor
RemiBecheru
Unfortunately that does not work, any other idea ?
JoelBennett
MVP Regular Contributor
It appears that you are using the Editor widget, so I think what you want is to capture the "create" event of the underlying SketchViewModel instance.  In that case, it would be something like:
editor.viewModel.sketchViewModel.on("create", function(evt) {
	if (evt.state == "complete") {
		//do something with evt.graphic here
