Editor Component and layerInfos
1511
7
07-25-2025 12:43 PM
NicholasRolstad2
I really hate that Esri is pushing these components SO hard yet have virtually no examples for how to work with them. I've had to just figure them out on my own in most cases but for the Editor I'm struggling. There is only one example I can find for the Editor component and its literally just this:
<arcgis-editor position="top-right"></arcgis-editor>
Real helpful stuff.
How do I attach layerInfos to this? I'm pulling my hair out trying to get it to work. No matter what I do it just loads every single layer from my webmap into the editor with no layerInfos.
I'm sure this is pretty straightforward, but I can't get it to work, anyone know how it's supposed to work?
JeffreyThompson2
MVP Frequent Contributor
Add an id to the Component in the HTML. Then you can grab it with document.getElementById() and add the layerInfos.
const editor = document.getElementById('editor')
editor.layerInfos = [
   //Your infos
GIS Developer
City of Arlington, Texas
JeffreyThompson2
   //Your infos
GIS Developer
NicholasRolstad2
So, that's what I thought! I must just have something else that's getting in the way for me. Good to have confirmation though, thanks!
NicholasRolstad2
I guess my real problem is that I cant figure out how to stop every single layer on my webmap from appearing in the editor, even ones with editing disabled.
JoseBanuelos
Hello @NicholasRolstad2 ,
Appreciate the feedback, we will work on updating more of our editing samples to use map components. In the meantime here is a codepen for grabbing a layer in a webmap, and disabling editing using the Editor.layerInfos.
https://codepen.io/banuelosj/pen/gbawaop
Jose
NicholasRolstad2
Thanks for the reply! I did eventually get it sorted by looping over every single layer and setting a layerInfo for them with editing disabled (except for the layer I wanted enabled). I don't remember that being necessary for non-editable layers in the widget version but maybe I'm just forgetting.
Thanks again!
JoseBanuelos
@NicholasRolstad2 ,
I am glad you were able to get this resolved! You don't have to do this for non-editable layers, since Editor will know which layers are not editable. The only way non-editable layers can show up in Editor, is if you are signed in as the data owner or an admin. Otherwise, they will not be available to be selected or to create features. If you are seeing non-editable data show up in Editor, please let us know and ideally provide an example.
Thanks!
Jose
NicholasRolstad2
AHHH. Okay, that makes sense then. I've been testing through an admin account primarily. Thanks!
