Edit Spatial Data in Javascrip API application
1180
09-15-2010 08:22 AM
MalleshManchala
Hello All,
I have Arcgis server 9.3 Map service, could anyone help or suggest that how can I modify polygon attributes and insert/delete/edit a polygon without using geoprocessing service in JavaScript API application. Thanks in advance.
Thanks
Mallesh
derekswingley1
If you're using 10 you can do this with a feature service. Check out the editing samples:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm
MalleshManchala
Hi swingley, Thanks for your reply, It is ArcGIS Server 9.3 Map service, any suggestions or idea.
derekswingley1
You're only option is the web adf. It's probably easier to upgrade...
