Edit FeatureTable cells
1609
09-06-2021 11:12 PM
NewUser222
Hi I am fairly new to ArcGIS, infact to coding altogether, so please excuse my elementary level doubt.
I am trying to create a FeatureTable with editable cells/features/rows. Will this be achieved using editor widget? Also, if there are multiple feature layers on the page, would using the editor widget enable editing in all of them or can the editor be 'confined' to editing only the FeatureTable?
UndralBatsukh
Hi there,
Are you using 4.x api? If so then you can enable: FeatureTable.editingEnabled to true. This SDK sample shows you how to enable an editing on a layer: https://developers.arcgis.com/javascript/latest/sample-code/widgets-featuretable-editing/
Hope this helps,
-Undral
UndralBatsukh
Hi there,
Hope this helps,
-Undral
NewUser222
Yes, using 4.20.
Thankyou for the solution, really helped.
