Edit an existing geometry on map
6919
13
11-11-2022 05:23 AM
DivyaArora
We are trying to integrate the ESRI Maps in a React Application. Using  ARCGIS API for JS 4.24, we are able to draw the map and add features like marker and boundary on the map.
Now, we need  to edit the geometry on the map by performing various operations like draw polygon, circle, split, move , delete etc. We could not find anything in the ARCGIS API for JS 4.24.
The document has some examples for ARCGIS API for JS 3.42 but in this case we are not able to render the map.
Using the code like below , we are getting the error : "Module not found: Error: Can't resolve 'esri/Map'"
import Map from "esri/Map";
 map = new Map("map", {
            basemap: "streets-vector",
            center: [-15.469, 36.428],
            zoom: 3
Any help regarding implementing the feature would be appreciated
JayakumarPD
How can i get the coordinates of the newly splitted polygons so that I can add them dynamically.
 const geometries = geometryEngine.cut(polygon1, line1);
 console.log(geometries); // here we will ge the newly created polygone
check the console, for that only I have applied the symbology.
Considering your example how can i identify the polygons that have been crossed by this polyline
const isCrossed = geometryEngine.crosses(polygon1, line1);
// if isCrossed is true then only perfor the cut else alert the user
if(isCrossed){
}else{
  alert("Kindly draw the line on polygone");
 Hope it solves the problem.
JayakumarPD
Hi Divya
You can refer this  https://github.com/Esri/react-arcgis/blob/master/demo/src/index.js
import { Map } from '@esri/react-arcgis';
Any how I am in my Next js solution using like this. there is no error. After installing the arcgis core.
import ArcGISMap from "@arcgis/core/Map";
const map = new ArcGISMap({
      basemap: "topo-vector",
     //  other porps can be set here
DivyaArora
Map is correctly working in ARcGis 4.2 version. I am looking for some edit operation on the existing geometry like splitting a polygon. Documentation refers using cut operation of Geometry engine but could not  understand the way how to use it.
JayakumarPD
Hi, kindly share the code I will try to help.
DivyaArora
I have followed the url "https://developers.arcgis.com/javascript/latest/calculate-geometries/" to implement the split functionality.
This worked for a single polygon now. Now, looking for splitting multiple polygons with a single polyline.  Could some one guide on this if this is the tight approach for implmenting a split operation.
Below is the code  :
 const sketchVM = new Sketch({
            layer: graphicsLayer,
            view: window.mapView,
            // graphic will be selected as soon as it is created
            creationMode: "update"
    const splitUsingGeomtryService = (polyline: any) => {
        const dissolvedGeometry = geometryEngine.union(window.lastpolygon);
        const splittedGeometry = geometryEngine.cut(dissolvedGeometry, polyline);
        console.log("splittedGeometry: ", splittedGeometry);
        graphicsLayer.removeAll();
        const intersection1Graphic = new Graphic({
            geometry: splittedGeometry[0] as any,
            symbol: {
                type: "simple-fill",
                style: "solid",
                color: "red",
                outline: {
                    color: "blue"
            } as any
       graphicsLayer.add(intersection1Graphic);
        const intersection2Graphic = new Graphic({
            geometry: splittedGeometry[1] as any,
            symbol: {
                style: "solid",
                color: "red",
                outline: {
                    color: "blue"
            } as any
       graphicsLayer.add(intersection2Graphic);
DivyaArora
Any guidance with a reference link or code is appreciated
JayakumarPD
I have hardcoded the polygon and polyline and performed cut polygon using geometryEngine, the task can also be done dynamically.  By clicking on cut button the operation will be performed.
<html lang="en">
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Cut Polygone | Sample | ArcGIS API for JavaScript 4.25</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.25/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.25/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/widgets/Sketch",
        "esri/Map",
        "esri/views/draw/Draw",
        "esri/Graphic",
        "esri/layers/GraphicsLayer",
        "esri/views/MapView",
        "esri/geometry/Polyline",
        "esri/geometry/Polygon",
        "esri/geometry/geometryEngine",
        Sketch,
        Map,
        Draw,
        Graphic,
        GraphicsLayer,
        MapView,
        Polyline,
        Polygon,
        geometryEngine
        // const graphicPolyline = new GraphicsLayer();
        const map = new Map({
        const view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 10,
          center: [75, 14],
        const rings1 = [
            [8323584.716104832, 1584076.9248102568],
            [8344681.335911548, 1605173.5446169735],
            [8360427.3637383, 1592484.9979216293],
            [8356911.260437181, 1567413.652644082],
            [8353089.409022921, 1549527.388025344],
            [8371434.29581137, 1568789.5191532157],
            [8386721.701468411, 1553807.8616093155],
            [8364707.837322271, 1533016.9899157395],
        const polygon1 = new Polygon({
          rings: rings1,
          hasZ: false,
          hasM: false,
          spatialReference: { wkid: 102100 },
        let polygoneGraphic1 = new Graphic({
          geometry: polygon1,
          symbol: {
            color: "gray",
            style: "solid",
            outline: {
              color: "yellow",
              width: 1,
        view.graphics.add(polygoneGraphic1);
        let paths1 = [
            [8322514.597708838, 1596153.9752793193],
            [8362873.348643427, 1574292.9851897506],
            [8379995.242979313, 1537450.3375562814],
        let line1 = new Polyline({
          hasZ: false,
          hasM: false,
          paths: paths1,
        const graphicPolyline1 = new Graphic({
          geometry: line1,
          symbol: {
            type: "simple-line",
            color: [200, 70, 30],
            width: 2,
        view.graphics.add(graphicPolyline1);
        function drawPolygon(event) {
          const vertices = event.vertices;
          let polygon = {
            type: "polygon",
            rings: vertices,
            spatialReference: view.spatialReference,
          console.log(polygon);
          let polygoneGraphic = new Graphic({
            geometry: polygon,
            symbol: {
              color: "gray",
              style: "solid",
              outline: {
                color: "yellow",
                width: 1,
          view.graphics.add(polygoneGraphic);
        function drawLine(event) {
          let polyline = {
            type: "polyline",
            hasZ: false,
            hasM: false,
            paths: vertices,
          console.log(polyline);
          const graphicPolyline = new Graphic({
            geometry: polyline,
            symbol: {
              width: 2,
          view.graphics.add(graphicPolyline);
        const draw = new Draw({
          view: view,
        document.getElementById("Polyline").onclick = () => {
          const action = draw.create("polyline");
          view.focus();
          action.on("vertex-add", drawLine);
        document.getElementById("Polygon").onclick = () => {
          const action = draw.create("polygon");
          view.focus();
          action.on("vertex-add", drawPolygon);
        view.ui.add(info, "top-right");
        view.when(() => {
          document.getElementById("handleClick").onclick = () => {
            console.log("cut started..");
            console.log("cut completed..");
            // just for my reference..
            const rings2 = [
                [8376763.972308426, 1544403.339624886],
                [8367399.716694297, 1564553.211080289],
            const polygon2 = new Polygon({
              rings: rings2,
              hasZ: false,
              hasM: false,
            let polygoneGraphic2 = new Graphic({
              geometry: polygon2,
              symbol: {
                color: "blue",
                style: "solid",
                outline: {
                  color: "red",
                  width: 1,
            view.graphics.add(polygoneGraphic2);
            const rings3 = [
                [8358228.865145299, 1576808.7470845701],
                [8331042.491026713, 1591534.6997321376],
            const polygon3 = new Polygon({
              rings: rings3,
              hasZ: false,
              hasM: false,
            let polygoneGraphic3 = new Graphic({
              geometry: polygon3,
              symbol: {
                color: "tomato",
                style: "solid",
                outline: {
                  color: "blue",
                  width: 1,
            view.graphics.add(polygoneGraphic3);
            const rings4 = [
            const polygon4 = new Polygon({
              rings: rings4,
              hasZ: false,
              hasM: false,
            let polygoneGraphic4 = new Graphic({
              geometry: polygon4,
              symbol: {
                color: "green",
                style: "solid",
                outline: {
                  color: "blue",
                  width: 1,
            view.graphics.add(polygoneGraphic4);
            const rings5 = [
            const polygon5 = new Polygon({
              rings: rings5,
              hasZ: false,
              hasM: false,
            let polygoneGraphic5 = new Graphic({
              geometry: polygon5,
              symbol: {
                color: "violet",
                style: "solid",
                outline: {
                  color: "blue",
                  width: 1,
            view.graphics.add(polygoneGraphic5);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
    <div id="info">
      <button id="Polygon">Polygon</button>
      <button id="Polyline">Polyline</button>
      <button id="handleClick">Cut</button>
    </div>
  </body>
</html>
DivyaArora
Thanks @JayakumarPD for the assistance but in your codebase you have added the hardcoded geometry at the  corrdinates of the initial polygon. How can i get the coordinates of the newly splitted polygons so that I can add them dynamically.
Considering your example how can i identify the polygons that have been crossed by this polyline  so that i can dynamically add the newly created geometries.
If you will refer my code I am able to perform cut on a single polygon that gives me 2 polygons but unable to dynamically handle the case mentioned by you (which is also my case)
JayakumarPD
if(isCrossed){
}else{
DivyaArora
crosses method helped me fix my issue. Thanks a lot 🙂
