Easily display route length?
7618
15
06-08-2015 08:41 AM
BenCamp
Is there an easy way to modify this sample to display the route length?  I've been working on this for a couple days and can't seem to get the length to display.  Thanks in advance for your help.
Simple Routing
TomSellsted
Ben,
Yes!  The result contains a polyline.  You can add a reference to the geometryEngine and calculate the length of the polyline using the geodesicLength method.  Something like this:
var routeLength = geometryEngine.geodesicLength(evt.results.routeResults[0].route.geometry);
You can also specify the UNITS that the length will return from the calculation or it will use the default from the geometry used.  In this case meters.
You can find out more about it here:
esri/geometry/geometryEngine | API Reference | ArcGIS API for JavaScript
Regards,
Tom
BenCamp
Tom
Thank you for the very helpful response. Would you mind pointing out where I've tripped up?
Thanks again for the assistance.
Ben
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Simple Routing</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
    <script src="http://js.arcgis.com/3.13/"></script>
    <script>
      require([
        "esri/urlUtils",
        "esri/map",
        "esri/graphic",
        "esri/tasks/RouteTask",
        "esri/tasks/RouteParameters",
        "esri/geometry/geometryEngine",
        "esri/tasks/FeatureSet",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/Color",
        "dojo/on",
        "dijit/registry",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dijit/form/HorizontalSlider",
        "dijit/form/HorizontalRuleLabels"
      ], function (
        urlUtils, Map, Graphic, RouteTask, RouteParameters, geometryEngine,
        FeatureSet, SimpleMarkerSymbol, SimpleLineSymbol,
        Color, on, registry
        var map, routeTask, routeParams;
        var stopSymbol, routeSymbol, lastStop;
        urlUtils.addProxyRule({
          urlPrefix: "route.arcgis.com",
          proxyUrl: "/sproxy/"
        map = new Map("map", {
            basemap : "streets",
            center : [-117.195, 34.057],
            zoom : 14
        map.on("click", addStop);
        routeTask = new RouteTask("http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World");
        //setup the route parameters
        routeParams = new RouteParameters();
        routeParams.stops = new FeatureSet();
        routeParams.outSpatialReference = {
          "wkid" : 102100
        routeTask.on("solve-complete", showRoute);
        routeTask.on("error", errorHandler);
        //define the symbology used to display the route
        stopSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CROSS).setSize(15);
        stopSymbol.outline.setWidth(4);
        routeSymbol = new SimpleLineSymbol().setColor(new dojo.Color([0, 0, 255, 0.5])).setWidth(5);
        //Adds a graphic when the user clicks the map. If 2 or more points exist, route is solved.
        function addStop(evt) {
          var stop = map.graphics.add(new Graphic(evt.mapPoint, stopSymbol));
          routeParams.stops.features.push(stop);
          if (routeParams.stops.features.length >= 2) {
            routeTask.solve(routeParams);
            lastStop = routeParams.stops.features.splice(0, 1)[0];
        //Adds the solved route to the map as a graphic
        function showRoute(evt) {
          map.graphics.add(evt.result.routeResults[0].route.setSymbol(routeSymbol));
          dojo.byId("length999").innerHTML = routeLength[0] + "feet";
        //Displays any error returned by the Route Task
        function errorHandler(err) {
          alert("An error occured\n" + err.message + "\n" + err.details.join("\n"));
          routeParams.stops.features.splice(0, 0, lastStop);
          map.graphics.remove(routeParams.stops.features.splice(1, 1)[0]);
    </script>
  </head>
  <body class="claro">
    <div id="map" style="width:600px; height:400px; border:1px solid #000;"></div>
     <p>Click on the map to add stops to the route. The route from the last stop to the newly added stop is calculated. If a stop is not reachable, it is removed and the last valid point is set as the starting point.</p>
     Length:<span id="length999"></span>
  </body>
</html>
TimWitt2
replace line 104 with this
dojo.byId("length999").innerHTML = evt.result.routeResults[0].route.attributes.Shape_Length + "feet";
You can remove line 107.
TomSellsted
Ben,
Tim is correct!  My apologies, you really don't need the geometryEngine.  With the attributes you have length specified in many ways.  There are attributes for Total_Kilometers and Total_Miles.
Regards,
Tom
TimWitt2
Tom,
that is the nice thing in programming there are always different options to do the same task
Tim
TomSellsted
Tim,
I absolutely agree!
Regards,
Tom
TomSellsted
Ben,
I am not sure that the Shape_Length is in feet...  I have been comparing it to the Total_Miles and Total_Kilometers and they don't calculate as expected.  Just wanted you to know...
Regards,
Tom
TimWitt2
Tom is right, I wonder in what unit the shape length is?
TomSellsted
Tim,
I thought it might be meters, but that doesn't calculate properly either.  I tried to look at the services directory for routing to see if might show what the default units are and it has been disabled.
Regards,
Tom
