DynamicMapServiceLayer not Visible onload
1218
07-08-2011 10:59 AM
TimothyWilcoxon
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/widget/widget_legendvisible.html
I saw this example and wanted to see if there was a way to have the check box not checked(dynampic map not visible) when the page was loaded. For example not have the "Fire" layer visible when the page was loaded.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Updating the legend to display visible layers</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.3/js/dojo/dijit/themes/claro/claro.css">
    <style>
      html, body { height: 98%; width: 98%; margin: 0; padding: 5px; }
      #rightPane{
        width:20%;
      #legendPane{
        border: solid #97DCF2 1px;
    </style>
    <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.3"></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.layout.AccordionContainer");
      dojo.require("esri.map");
      dojo.require("esri.dijit.Legend");
      dojo.require("esri.arcgis.utils");
      dojo.require("dijit.form.CheckBox");
      var map;
      var legendLayers = [];
      function init() {
        var initialExtent = new esri.geometry.Extent({"xmin":-13133288,"ymin":4020012,"xmax":-13016186,"ymax":4090945,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map", { extent: initialExtent});
        //Add the terrain service to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
        var quakeLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/EarthquakesFromLastSevenDays/MapServer",{id:'quakes'});
        legendLayers.push({layer:quakeLayer,title:'Earthquakes'});
        var fireLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/MapServer",{id:'fire'});
        legendLayers.push({layer:fireLayer,title:"Fire"});
        dojo.connect(map,'onLayersAddResult',function(results){
          var legend = new esri.dijit.Legend({
            map:map,
            layerInfos:legendLayers
          },"legendDiv");
          legend.startup();
        map.addLayers([fireLayer,quakeLayer]);
        //add check boxes
        dojo.forEach(legendLayers,function(layer){
         var layerName = layer.title;
         var checkBox = new dijit.form.CheckBox({
            name: "checkBox" + layer.layer.id,
            value: layer.layer.id,
            checked: layer.layer.visible,
            onChange: function(evt) {
              var clayer = map.getLayer(this.value);
              if (clayer.visible) {
                clayer.hide();
              } else {
                clayer.show();
              this.checked = clayer.visible;
          //add the check box and label to the toc
          dojo.place(checkBox.domNode,dojo.byId("toggle"),"after");
          var checkLabel = dojo.create('label',{'for':checkBox.name, innerHTML:layerName},checkBox.domNode,"after");
           dojo.place("<br />",checkLabel,"after");
        //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in
        //the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm
        var resizeTimer;
        dojo.connect(map, 'onLoad', function(theMap) {
          dojo.connect(dijit.byId('map'), 'resize', function() {  //resize the map if the div is resized
            clearTimeout(resizeTimer);
            resizeTimer = setTimeout( function() {
              map.resize();
              map.reposition();
            }, 500);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
      <div id="rightPane" dojotype="dijit.layout.ContentPane" region="right">
        <div dojoType="dijit.layout.AccordionContainer">
          <div dojoType="dijit.layout.ContentPane" id="legendPane" title="Legend"  selected="true">
            <div id="legendDiv"></div>
          </div>
          <div dojoType="dijit.layout.ContentPane" title="Natural Disasters" >
            <span style="padding:10px 0;">Click to toggle the visibilty of the various natural disasters</span>
            <div id="toggle" style="padding: 2px 2px;"></div>
          </div>
        </div>
      </div>
      <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;">
      </div>
    </div>
  </body>
</html>
HemingZhu
<html>
  <head>
      on iOS devices-->
    <style>
      #rightPane{
        width:20%;
      #legendPane{
    </style>
      var map;
      function init() {
            map:map,
          },"legendDiv");
          legend.startup();
        //add check boxes
                clayer.hide();
              } else {
                clayer.show();
        var resizeTimer;
              map.resize();
              map.reposition();
            }, 500);
    </script>
  </head>
          </div>
          </div>
        </div>
      </div>
      </div>
    </div>
  </body>
</html>
 var fireLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/MapServer",{id:'fire', visible:false});
