'dynamicLayers' is not enabled on this MapService.
4047
10-10-2014 04:45 PM
RobertScheitlin__GISP
Is there a way to check if dynamicLayers are supported by a map service though the API or do I have to just parse the json request manually to get the "supportsDynamicLayers": false
KellyHutchins
Esri Notable Contributor
ArcGIDDynamicMapServiceLayer has a property called supportsDynamicLayers you can use to test this. Looks like this property has not been documented. I'll make sure it gets documented for the next release. In the meantime here's an example showing how this works.
      var layer = new ArcGISDynamicMapServiceLayer("http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Energy/Geology/MapServer");
      layer.on("load", function(){
        console.log(layer.supportsDynamicLayers);
      map.addLayer(layer);
KellyHutchins
Kelly,
   Thanks for confirming supportsDynamicLayers property on ArcGISDynamicMapServiceLayer does exist.
