Dynamically Drawing a Line
962
01-25-2014 03:30 AM
jeffpalus
is there a way to Dynamically Drawing a Line (Adding points to a line in an animation)
Example: https://www.mapbox.com/mapbox.js/example/v1.0.0/dynamically-drawing-a-line/
RobertoPepato
This is a sample using points:
http://developers.arcgis.com/javascript/samples/layers_streamlayer/
You can use it as an insight to build your own using lines:
https://developers.arcgis.com/javascript/jsapi/polyline.html#polyline3
Let me know if it helps
