Dynamic Placement of Polygon Labels
3032
12-20-2023 07:12 AM
JeffreyThompson2
MVP Frequent Contributor
I have a polygon FeatureLayer with labels turned on. The labels appear to be fixed in position at the centroid of the polygon.
I would like them to reposition themselves, so that the label is always visible regardless of the zoom level. So a zoomed in view like this is still labeled.
Is this supported by the API? According to the documentation, the only polygon label placement option is 'always-horizontal'. https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-LabelClass.html#la...
This seems like very basic behavior so I'd be surprised if it's not supported. Any suggestions or work-arounds?
GIS Developer
City of Arlington, Texas
JeffreyThompson2
I have developed a workaround. The FeatureLayer in my case is created from a MapImageLayer and a MapImageLayer does handle dynamic repositioning. I have used the MapImageLayer to effectively create a layer that only contains labels and loaded it to my map as well as the FeatureLayer which handles all the other attributes on the map.
This creates a MapImageLayer with only the sublayer I want and hides everything but the labels.
//Label only mapImageLayer
const mapImage = new MapImageLayer({
   url: 'url',
   listMode: hide,
   sublayers: [
                        legendEnabled: false,
                        listMode: 'hide',
                        opacity: 0
 I gave my FeatureLayer a LabelClass with a labelExpressionInfo of an empty string to trick it into thinking it's doing the labeling.
labelClass: [
        labelExpressionInfo: {
            expression: ' '
        symbol: {
            type: 'text',
            color: 'black',
            font: {
                family: 'Noto Sans',
                weight: 'normal'
        labelPlacement: 'always-horizontal'
And I used reactiveUtils to turn on/off the MapImageLayer when the layer it is tied to or its labels are turned on/off.
sublayer8 = mapImage.findSublayerById(8)
feature8 = jimuMapView.view.map.findLayerById('featureLayer8')
reactiveUtils.watch(() => [feature8?.visible, feature8?.labelsVisible], ([visible, labels]) => {
	if (visible && labels) {
		sublayer8.visible = true
	} else {
		sublayer8.visible = false
GIS Developer
SaurabhUpadhyaya
I am also facing the same issue, trying to fixe the label position dynamically.
Also facing the issue, label text is not displaying correctly in print map. Can anyone suggest .
JeffreyThompson2
   url: 'url',
   listMode: hide,
   sublayers: [
                        listMode: 'hide',
                        opacity: 0
labelClass: [
            expression: ' '
        symbol: {
            type: 'text',
            color: 'black',
            font: {
                weight: 'normal'
	} else {
GIS Developer
NicolasGIS
Honored Contributor
