Drawing multiple Polygons
1852
02-09-2024 08:17 PM
Charan
Hi everyone, I am trying to draw multiple polygons on the map. I'm able to draw them but I cant not see the vertices or the outline.
          let drawnPolygons = [];
          document.getElementById("drawPolygon").onclick = () => {
            if (
              document.getElementById("tradereport3").style.display == "none"
              document.getElementById("tradereport3").style.display = "block";
            document.getElementById("tradereport1").style.display = "none";
            document.getElementById("tradereport2").style.display = "none";
            document.getElementById("tradereport4").style.display = "none";
            const action = draw.create("polygon");
            action.on(
                "vertex-add",
                "vertex-remove",
                "cursor-update",
                "redo",
                "undo",
                "draw-complete",
              PolygonVertices
          function PolygonVertices(event) {
            if (event.type === "draw-complete" && event.vertices.length > 1) {
              const result = createPolygon(event);
              drawnPolygons.push(result)
              PolygonBufferGeom()
          function createPolygon(event) {
            const vertices = event.vertices;
            const graphicpoly = new Graphic({
              geometry: {
                type: "polygon",
                rings: [vertices],
                spatialReference: view.spatialReference,
              symbol: {
                type: "simple-fill",
                color: [234, 136, 8, 0.1],
                outline: {
                  color: [234, 136, 8, 10],
                  width: 1,
            view.graphics.add(graphicpoly);
            return graphicpoly
'If I don't do event.type === "draw-complete, my polygons end up following the cursor movement, like this;
@JoelBennett @Sage_Wall @UndralBatsukh
UndralBatsukh
Hi there,
Can you please clarify what the issue is here? I am not clear on what the end goal is.
Charan
Hi @UndralBatsukh so when Im drawing the polygons I cant see the shape of the polygon until I finish it off, but if i remove event.tuype=="drawing" i can see the polygons while drawing but they are being created based on cursor movement
UndralBatsukh
This codepen shows how to draw polygons using SketchViewModel: https://codepen.io/U_B_U/pen/WNmYRrV?editors=1000
