Draw toolbar cancel last vertex
1742
08-02-2013 01:07 AM
mykLT
Hello,
I need to cancel last vertex drawn using Draw toolbar with geometry types POLYGON or POLYLINE and do not interrupt drawing process (geometry should be redrawn).
I implemented it like this:
var dt = drawToolbar; // NOTE: from somewhere
var points = dt._points;
if (points.length > 1) {
    var geom = dt._graphic.geometry;
    geom.removePoint(0, points.length - 1);
    points.splice(points.length - 1, 1);
    dt._graphic.setGeometry(geom);
    var start = points[points.length - 1];
    var tempGeom = dt._tGraphic.geometry;
    tempGeom.setPoint(0, 0, start.offset(0, 0));
    tempGeom.setPoint(0, 1, start.offset(0, 0));
    dt._tGraphic.setGeometry(tempGeom);
} else {
    dt._points = [];
    dt._onMouseMoveHandler_connect.remove();
    dt._clear();
But as You can see, it uses private attributes. It would be nice, if ESRI would implement this functionality in later releases, because it's really useful, I think. Maybe someone has an idea how to avoid using privates?
vittoriosanzari
thank-you
very useful
GianniContino
thanks for the function,
but I'd like to know what rows 10..14 are written for..
are they necessary?
bye
Gianni
