Draw tool doesn't account for changes in map position after page loads
1158
07-07-2011 01:48 PM
KenDeeds
I've set up a link below to show this.  If a page loads, and you intend to have the user use the toolbar Draw tool, and you have anything happen that changes the map position, the Draw tool does not offset to account for this.
I know how to find the offset or change of the map position, but is there a way to apply this offset to the draw tool so it draws under the cursor and accounts for the position change?
http://v39.consensusdev.com/test.php
In the link above just draw once, everything works.  Then expand the div, draw again, you'll notice the offset issue.
KellyHutchins
Esri Notable Contributor
You need to update the map's size and position. Try adding the map.resize and map.reposition to your expand and hide functions:
   function expand(){
document.getElementById('expand').style.height='110px';
    map.resize();
    map.reposition();
KenDeeds
Thanks for the reply, did the trick.
