draw path and 3d line
4431
7
11-26-2018 01:55 AM
anjelinaponkerat
Hi
I,m working on showing 3d line as a path in arcgis java script api 4.X in  scene viewe. but I have a big problem:
some piece of my lines have drawn underground. I am using : "relative-to-ground" for elevation info of my 2d feature layer and image service for topographic of earth.
please check attached files.
RobertScheitlin__GISP
anjelinaponkerat
but what about other parts? In this case, those parts that were previously correct are corrupted and moved upward!!
Anjelina,
   Does your data contain Z (elevation) info?
anjelinaponkerat
No, my data is 2d. I tried to convert my line to 3d, but because of that my DEM is surface(not TIN), conversion is just applicable by Bilinear method(Arc map) and this method interpolate 4 pixel to 1 pixel and my 3d line move down or up !!!
Anjelina,
  Have you tried "on-the-ground"?
anjelinaponkerat
yes, but result is not better!
JohnGrayson
Esri Alum
Have you tried densifying the feature polyline geometries?  Not sure, but it could be that only vertices are "relative-to-ground" and the sections between vertices are not?
