Drag Graphics Point and Drop at New Location
19166
17
04-18-2011 03:37 PM
ManishGohil
Hello All,
  We have our application developed in .Net using WebADF Map controls.
  I need help on how i can implement the "drag graphics point" functionality in our application that built using WebADF.Net controls.
I found that using dojo we can implement drag/drop but i am not able to use dojo with Map control of WebADF.
I also want to know what are the different approach/implementation for drag/drop graphics on Map?
Any help will be appreciated.
One similar post that never replied :
http://forums.esri.com/Thread.asp?c=158&f=2396&t=286884
Lala Rabari
AshishRao
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>ArcGIS Drag'n'drop sample</title>
<%--    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.3/js/dojo/dijit/themes/claro/claro.css" />
    <link rel="stylesheet" type="text/css" href= "http://serverapi.arcgisonline.com/jsapi/arcgis/1.2/js/dojo/dijit/themes/tundra/tundra.css" />
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis?v=1.2"></script>--%>
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
    <script src="DragAndDrop.js" type="text/javascript"></script>
    <script type="text/javascript">
        var map      = null;
        var pushpin  = null;
        var pushpin2 = null;
        dojo.require("esri.map");
        dojo.addOnLoad(function() {
            dojo.style(dojo.byId("map"), { width: dojo.contentBox("map").w + "px", height: dojo.contentBox("map").h + "px" });
            esriConfig.defaults.map.slider = { right: "10px", top: "10px", width: null, height: "100px" };
            map = new esri.Map("map", { wrapAround180: true, nav: false });
           // map = new esri.Map("map", {basemap: "topo", center: [71.55, 21.55], zoom: 5,sliderStyle: "small"});
            // pushpins will be added after map layers is loaded
            dojo.connect(map, "onLoad", function() {
                var mapPoint = new esri.geometry.Point(-13042885, 4033247, new esri.SpatialReference({ wkid: 102100 }));
                pushpin = new Pushpin(map, "http://static.arcgis.com/images/Symbols/Basic/AmberBeacon.png", 25, 25, mapPoint);
                var mapPoint2 = new esri.geometry.Point(-13042885, 2033244, new esri.SpatialReference({ wkid: 102100 }));
                pushpin2 = new Pushpin(map, "http://static.arcgis.com/images/Symbols/Basic/AmberBeacon.png", 25, 25, mapPoint2);
            var layer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
            map.addLayer(layer);
            //var tmpPushpinCurretnLocation = pushpin2.GetCurrentLocation();
            //pushpin.Dispose();
            //pushpin2.Dispose();
    </script>
</head>
<body class="claro">
    <form id="form1" runat="server">
        <div id="map" style="position:absolute; left:400px; top:100px; width:1024px; height:512px;border: 1px solid #A8A8A8; background-color:#ffffff; " />
    </form>
</body>
</html>
DragAndDrop.js
        // represents wrapper for graphic object to provide drag'n'drop ability
        // map     - instance of esri.Map
        // graphic - instance of esri.Graphic
        function DragableGraphic(map, graphic) {
            this._map             = map;              // parent map
            this._graphic         = graphic;          // moveable graphic object
            this._currentLocation = graphic.geometry; // current location of graphic object
            this._isInUse         = false;            // true if graphic object is in dragging
            this._onMouseDownHandler    = null;  // pointer to onMouseDown    event handler
            this._onMouseUpHandler      = null;  // pointer to onMouseUp      event handler
            this._onMouseDragHandler    = null;  // pointer to onMouseDrag    event handler
            this._onMouseDragEndHandler = null;  // pointer to onMouseDragEnd event handler
            // initializes object
            this._init = function () {
                // bind to onMouseDown that fires when graphic object is clicked on
                if (this._onMouseDownHandler == null)
                    dojo.connect(this._map.graphics, "onMouseOver",this, function (evt) {
                        if (evt.graphic === this._graphic) {
                            evt.graphic.getDojoShape().moveToFront();
                    }); //End onMouseOver //added
                    dojo.connect(this._map.graphics, "onMouseOut", this, function (evt) {
                            evt.graphic.getDojoShape().moveToBack();
                    }); //End onMouseOut //added
                this._onMouseDownHandler = dojo.connect(this._map.graphics, "onMouseDown", this, this.onMouseDown);
            // releases resources used by object
            this.Dispose = function() {
                // disconnect from onMouseDown
                if (this._onMouseDownHandler != null) {
                    dojo.disconnect(this._onMouseDownHandler);
                // if graphic object is in use, release it
                if (this._isInUse) {
                    this._map.enableMapNavigation(); // enable default left button behavior
                    this.unbindDragNDropEvents();    // disconnect from drag'n'drop events
                    this._isInUse = false;           // mark graphic object as not in use
            // binds to drag'n'drop events
            this.bindToDragNDropEvents = function() {
                // bind to onMouseDrag that fires when graphic object is being dragged
                if (this._onMouseDragHandler == null)
                    this._onMouseDragHandler = dojo.connect(this._map, "onMouseDrag", this, this.onMouseDrag);
                // bind to onMouseDragEnd that fires when graphic object is dropped
                if (this._onMouseUpHandler == null)
                    this._onMouseUpHandler = dojo.connect(this._map.graphics, "onMouseUp", this, this.onMouseUp);
            // unbinds from drag'n'drop events
            this.unbindDragNDropEvents = function() {
                // disconnect from onMouseDrag
                if (this._onMouseDragHandler != null) {
                    dojo.disconnect(this._onMouseDragHandler);
                // disconnect from onMouseUp
                if (this._onMouseUpHandler != null) {
                    dojo.disconnect(this._onMouseUpHandler);
            // fires when graphic object is clicked on
            this.onMouseDown = function (event) {
                // if graphic object isn't in use yet, start using it
                this._isInUse = false;  //added
                if (!this._isInUse) {
                    this._isInUse = true;             // mark graphic object as in use
                    this._map.disableMapNavigation(); // prevent default left button behavior
                    if (event.graphic == this._graphic) { //added
                         this.bindToDragNDropEvents();     // connect to drag'n'drop events
                if (event.button != 0) //old is 1 ,0 is added// ignore if clicked button is not a left one
                    return;
                // ignore if clicked graphic object is not an object contained in the current DragableGraphic-object
                if (event.graphic != this._graphic)
                    return;
            // fires when graphic object is dropped
            this.onMouseUp = function (event) {
                    this._currentLocation = event.mapPoint;    // preserve end graphic object location
                    this._graphic.setGeometry(event.mapPoint); // move graphic object to the end location
                    return;
                    return;
            // fires when graphic object is being dragged
            this.onMouseDrag = function(event) {
                    this._currentLocation = event.mapPoint;    // preserve a new graphic object location
                    this._graphic.setGeometry(event.mapPoint); // move graphic object to the new location
            this._init(); // initialize object
        // represents wrapper for DragableGraphic
        // imgUrl   - string-based image url
        // height   - image height in pixels
        // height   - image width  in pixels
        // mapPoint - instance of esri.geometry.Point
        function Pushpin(map, imgUrl, height, width, mapPoint) {
            this._initialLocation = mapPoint; // initial location of pushpin
            this._height          = height;   // pushpin image height
            this._width           = width;    // pushpin image width
            this._imgUrl          = imgUrl;   // pushpin image url
            this._dragableGraphic = null;     // reference to DragableGraphic object
                // create PictureMarkerSymbol
                var symbol = new esri.symbol.PictureMarkerSymbol(this._imgUrl, this._width, this._height);
                // create graphic object based on symbol
                var graphic = new esri.Graphic(this._initialLocation);
                graphic.setSymbol(symbol);
                // add graphic object to the map
                this._map.graphics.add(graphic);
                // create DragableGraphic object to provide drag'n'drop ability for graphic object
                this._dragableGraphic = new DragableGraphic(this._map, graphic);
                if (this._dragableGraphic != null) {
                    // remove graphic object from the map
                    this._map.graphics.remove(this._dragableGraphic._graphic);
                    // call Dispose of DragableGraphic
                    this._dragableGraphic.Dispose();
            // returns the current location of Pushpin on the map
            this.GetCurrentLocation = function() {
                    return this._dragableGraphic._currentLocation;
                else
                    return null;
Joachim_EckboJuell
Hi Bjørn,
Yes, you're right. The "moveable" part disappear when the graphic leaves the visible area, and then enters again. That is probably because the API does some internal optimization(?) when graphics are not visible.
I tried to set the dojo shape moveable on "mouse over" on the graphics layer, and then remove the moveable stuff on "mouse out". But I was never able to remove the moveability of the shape (the only method I found was destroy, but that didn't seem to work). So the graphic just started moving x times faster than the mouse for each time I hovered the graphic.
So I ended up with a similar code as above, but with the graphic moving when the mouse moves. This is probably more CPU-heavy, and the code has some weeknesses (eg. if the mouse up event is never fired due to the mouse moving too fast). But its a starting point.
 dojo.connect(this._glStops, "onMouseDown", this, function (event) {
            this._moveableStop = event.graphic;
            this.map.disableMapNavigation();
            this._moveableStopLink = dojo.connect(this.map, "onMouseDrag", this, function (event) {
                this._moveableStop.setGeometry(event.mapPoint);
        dojo.connect(this._glStops, "onMouseUp", this, function (event) {
            this.map.enableMapNavigation();
            if (this._moveableStopLink) {
                dojo.disconnect(this._moveableStopLink);
                this._moveableStopLink = null;
Good luck with the travel planner.
Roman_Net_Follower
Hi, everyone!
In my project I've had to implement the drag'n'drop functionality for graphic object using ArcGIS JavaScript API. Probably it will be useful for somebody. It's shown in my blog here - http://dotnetfollower.com/wordpress/2011/07/arcgis-javascript-api-how-to-implement-dragndropping-of-...
Thanks!
JohnCorrea
Hey nice work on this example. There are some annoying discrepancies that can be easily fixed with an extra variable and a control statement. This will allow the user to go pack to panning after clicking and dragging while also not moving the point when they are off the graphic when actually attempting to pan.
At the top add
var clicked = false;
Then for the holdGraphic and releaseGraphic methods add
function
holdGraphic(evt) {
    clicked = true;
    map.disablePan();
    graphic = evt.graphic;
    graphic.setSymbol(dragSymbol);
function releaseGraphic(evt) {
    if (clicked == true) {
    graphic.geometry = evt.mapPoint;
    map.disablePan();
    /* code here is not relevant
    formPoint = esri.geometry.webMercatorToGeographic(evt.mapPoint);
    document.getElementById("Longitude").value = Math.round(formPoint.x * 100000) / 100000;
    document.getElementById("Latitude").value = Math.round(formPoint.y * 100000) / 100000;
clicked = false;
map.enablePan();
AdrianMarsden
Honored Contributor
Arrggh, I bookmarked this thread because the demo http://help.arcgis.com/en/webapi/javascript/arcgis/samples/graphics/graphics_extent_query.html mentioned earlier seemed useful, but that is now 404ing.  Anyone know what has happened to it?
KenMorefield
I believe the sample you are referring to is found here: SAMPLE
Ken
AdrianMarsden
Honored Contributor
That's it - Cheers.
Vermiedelos_reyes
Hi guys,
Glad to see this thread. Its very informative especially to newbies like me. Can you also help me with my problem? I need to create a Marker graphics with label on it. I understand that to be able to do these, I need to create two graphic object to be added to the map graphic layer. But my problem is i need to place several 'marker' graphics and its corresponding 'text' graphics inside the map. Can you please tell me how to work on this. I badly need your help.
