dojo.require("agsjs.dijit.TOC");
1454
01-04-2013 07:42 AM
JoseSanchez
I copied the source code from this page in my project and it works fine with version v=2.4  but in my form I am running  v=3.2 it crashes.
how can I make it work in version v=3.2?
http://gmaps-utility-gis.googlecode.com/svn-history/r354/trunk/agsjs/examples/toc.html
  <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4">
        </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2">
    </script>
CraigMcDade
what build of the TOC are you using? I am using version 3.2 of the API and build 2.04 of the TOC and it works fine.
 var djConfig = {
              parseOnLoad: true,
              packages: [{
                "name": "agsjs",
                "location": location.pathname.replace(/\/[^/]+$/, "")+'/Path/To/agsjs',
                "location": 'https://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.04/xbuild/agsjs' // for xdomain load
JoseSanchez
where do I find the build of the TOC?
I just copied your var djConfig   and it worked thank you.
 var djConfig = {
              parseOnLoad: true,
              packages: [{
                "name": "agsjs",
CraigMcDade
it'll be at the very top of your code just above the dojo.require statements. You should make sure your agsjs folder is referenced properly in this code as well.
JohnGravois
i confirmed the same.  perhaps you could mark craig's post as the answer?
