How to determine current XY of Map's Center?
1636
01-04-2013 06:51 AM
EdwardHinkle
I've read extensively through the API and various resources. I've done some great and unordinary things with the API but I can't seem to figure out how to detect the center of the map. The reason is I need to be able to resize the map and keep the center of the map as the center of the map despite the resizes and changes.
Currently when I resize the map, it adds more map space or remove map space on the size that is resized. I know I can use .centerAt() to center the map, however I need the X, Y from the current map center before the resize so I can re-center after the resize.
Thanks!
Eddie
JohnGravois
you should be able to use getCenter() and pass the map extent.
JohnGravois
EdwardHinkle
Perfect!! Thanks 🙂
