dojo/promise/all not working with esri/request
4368
10-05-2015 11:23 AM
JasonLevine
This seems pretty straightforward, but I'm unable to get it to work.
I'd like to get the layer infos for selected layers in my map service using multiple esri/requests with a promise.  I have a visibleLayers array that I'm using to create each request:
<code>
var visibleLayers = [0,1];
var requestGroup = [];
array.forEach(visibleLayers, function(visibleLayer,i)
     var requestHandle = esriRequest(
          url: dynamicLayer.url+"/"+visibleLayer,
          content: {f: "json"},
          callbackParamName: "callback"
     requestGroup.push(requestHandle);
promises = all(requestGroup);
promises.then(processResults);
function processResults(results)
          //process results
</code>
Everything looks ok, but I never enter my processResults function.  I know that the return for esriRequest is deferred, so I'm not sure what's going wrong.
Any ideas?
Jason
JasonLevine
Never mind.  For some reason, the following works:
all(requestGroup).then(function(results)
          //process results
