Dojo Loader with Backbone and Marionette
1583
02-07-2014 06:14 AM
EdwardRozum
Hey Everyone,
I have hit a road block when trying to use the Dojo Loader instead of require.js to build a backbone.marionette map application. I have looked through the forums, and used this (https://github.com/odoe/ags30sample) as an example. This issue I am running into seems to be the way the scripts are loading.
90% of the time, the app fails to start with the following error:
ReferenceError: Backbone is not defined
TypeError: Backbone.Marionette is undefined
The strange thing is, that sometimes the app does start. I can watch the http requests in fiddler, and they are being accessed in the correct order and loaded at the correct time. I was hoping you all could take a look, and explain if I am missing something. Any help would be greatly appreciated. I am new to modular and amd design, but have completed a few non map applications using require.js backbone and marionette
index.html
<script type="text/javascript" src="http://js.arcgis.com/3.8/"></script>
<script type='text/javascript' src='./Client/js/app_config.js'></script>
app_config.js
(function () {
    require({
        async: true,
        parseOnLoad: true,
        aliases: [["text", "dojo/text"]],
        packages: [
              location: location.pathname.replace(/\/[^/]+$/, "") + "/Client/js/vendor",
              main: "jquery"
              main: "bootstrap.min"
              main: "underscore"
              main: "backbone"
              main: "backbone.marionette"
              location: location.pathname.replace(/\/[^/]+$/, "") + "/Client/js"
    define.amd.jQuery = true;
    require(['jquery', 'app/app_main'], function ($, MapManager) {
        $(document).ready(function () {
            alert("here");
            MapManager.start();
}).call(this);
app_main.js
define(["jquery", "underscore", "backbone", "marionette"], function ($, _, Backbone, Marionette) {
    var MapManager = new Backbone.Marionette.Application();
    MapManager.addRegions({
        headerRegion: "#header-region",
        mainRegion: "#map-container",
    //After the Main application has started, startup the application views
    MapManager.on("initialize:after", function () {
        console.log("Marionette App started");
    return MapManager;
