Dojo in new version 3.7
2098
10-14-2013 04:54 AM
WesleyAntal2
I want to know in example https://developers.arcgis.com/en/javascript/jssamples/gp_clipasync.html o dojox.layout.Dock not work in version API 3.7, only version 3.6.
Exists a alternative to work in version 3.7?
BenFousek
It's still there and working in 3.7. The sample doesn't seem to work for an unrelated reason. If you are using AMD you need to require dojox/layout/Dock. The legacy floating pane require loaded the dock module.
AMD:
require([
  'dojox/layout/FloatingPane',
  'dojox/layout/Dock',
  'dojo/dom-construct',
  'dojo/_base/window'
], function (FloatingPane, Dock, domConstruct, win) {
  var dock = new Dock({
    //params
  }, domConstruct.create('div', null, win.body()));
  var fp = new FloatingPane({
    //params
    dockTo: dock
  fp.startup();
WesleyAntal2
AMD:
require([
  'dojo/_base/window'
    //params
    //params
    dockTo: dock
  fp.startup();
I not using AMD, just try add the require "dojo.require("dojox.layout.Dock");" this example above (https://developers.arcgis.com/en/javascript/jssamples/gp_clipasync.html) and not working. You try without AMD?
BenFousek
The sample is working. The dock is there and functioning. The problem is the floating pane is not visible by default and the dock isn't showing for some reason. It might be styling.
You can manually show the floating pane by running
dijit.byId('floater').show()
in the console.
Try moving the divs for the dock and floating pane outside the border container div.
Also try setting the 'map' to 'z-index:1;' and the 'dock' to 'z-index:50;'.
I use a lot of floating panes, but I hide the dock and show floating panes with buttons, etc.
