Dojo DataGid doesnot show in Infowindow
2725
11-30-2016 11:27 PM
DeepikaJain1
Hi I am trying place my datagrid into map infowindow but it doesnot show up, where as all the other contents do come up such as buttons etc.
here is the snippet of code:
var cp1 = new ContentPane({
title: "Expired VBB Report",
style: "width:500px;height:500px;"
// innerHTML:"this is test"
var myMemoryStore = new Memory(
{ data: [
{ 'id': '0', 'lastname': 'Frank' },
{ 'id': '1', 'lastname': 'Herbert'}]
var myObjectStore = new ObjectStore({ objectStore: myMemoryStore });
var myStructure = [
{ type: "dojox.grid._CheckBoxSelector" },
{ 'name': 'Column 1', 'field': 'id', 'width': '20%' },
{ 'name': 'Column 2', 'field': 'lastname', 'width': '20%', formatter: this.createLink }
var ShowVBBGrid = new DataGrid({
//id:'ShowVBBGrid',
store: myObjectStore,
structure: myStructure,
autoHeight: true
//selectionMode: "single",
// style: "width:400px;height:400px;display:block"
 dojo.place(ShowVBBGrid.domNode, cp1.containerNode, 'first');
// cp1.set("content", ShowVBBGrid.domNode);
ShowVBBGrid.startup();
 this.map.infoWindow.setTitle("Section58 Values");
this.map.infoWindow.resize(600, 500);
this.map.infoWindow.setContent(cp1.containerNode);
 this.map.infoWindow.show();
RobertScheitlin__GISP
Deepika,
   Here is a sample that shows how to use the new v 1.1 dgrid in the map info window:
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>Basemap gallery</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.18/dgrid1/css/dgrid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.18/esri/css/esri.css">
    <style>
        html,
        body {
            height: 100%;
            width: 100%;
            margin: 0;
            padding: 0;
        #map {
            padding: 0;
        .dgrid {
          height: 180px;
        .dgrid .field-id {
            width: 20%;
        .dgrid .field-lastname {
            width: 70%;
        .dgrid .field-col1 {
          width: 10%;
    </style>
    <script src="http://js.arcgis.com/3.18/"></script>
    <script>
        var map;
        require([
            "dojo/_base/declare", "dojo/on", "esri/map",
            "dojo/parser",
            "dstore/Memory",
            "dgrid1/OnDemandGrid",
            "dgrid1/Selector",
            "dgrid1/extensions/DijitRegistry",
            "dijit/layout/BorderContainer",
            "dijit/layout/ContentPane",
            "dijit/TitlePane",
            "dojo/domReady!"
        ], function(
            declare, on, Map,
            parser, Memory, Grid, Selector, DijitRegistry, BorderContainer, ContentPane
            parser.parse();
            map = new Map("map", {
                basemap: "topo",
                center: [-105.255, 40.022],
                zoom: 13
            map.on("load", function(){
                  style: "width:500px;height:200px;"
              var data = [
                  'oid': '0',
                  'lastname': 'Frank'
                  'oid': '1',
              var store = new Memory({ data: data });
              var dataGrid = new(declare([Grid, Selector, DijitRegistry]))({
                  bufferRows: Infinity,
                  selectionMode: "none",
                  collection: store,
                  columns: {
                    col1: { label:"", selector: 'checkbox'},
                    oid: { label: "Id"},
                    lastname: { label: "Last Name"}
              cp1.addChild(dataGrid);
              cp1.startup();
              map.infoWindow.resize(530, 320);
              map.infoWindow.setContent(cp1.domNode);
              dataGrid.resize();
    </script>
</head>
<body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;margin:0;">
        <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="padding:0;">
        </div>
    </div>
</body>
</html>
KenBuja
MVP Esteemed Contributor
Are there error messages in the console? Can you show more of your code?
Finally, DataGrid has been deprecated and you should move to using dGrid (v 1.1 or v 0.3).
Deepika,
<!DOCTYPE html>
<html>
<head>
    <style>
        html,
        body {
            height: 100%;
            width: 100%;
            margin: 0;
            padding: 0;
        #map {
            padding: 0;
        .dgrid {
          height: 180px;
        .dgrid .field-id {
            width: 20%;
            width: 70%;
          width: 10%;
    </style>
    <script>
        var map;
        require([
            "dojo/parser",
            "dstore/Memory",
            "dgrid1/Selector",
            "dijit/TitlePane",
            "dojo/domReady!"
        ], function(
            declare, on, Map,
            parser.parse();
                basemap: "topo",
                zoom: 13
              var data = [
                  'oid': '0',
                  'lastname': 'Frank'
                  'oid': '1',
                  collection: store,
                  columns: {
              cp1.startup();
              dataGrid.resize();
    </script>
</head>
        </div>
    </div>
</body>
</html>
DeepikaJain1
Thanks Rob for all the help and efforts, it worked magically
