Dojo Data Grid Zoom To.
978
04-22-2014 09:00 AM
deleted-user-yA_w_FC9FKe5
So I am trying to combine a couple of samples together.  The first thing I did was used this example to create a search on my point feature layer.  It took some modification because the sample was on polygons and I am using points.  So I had to use a SimpleMarkerSymbol.  So basically the lines that are commented out were the ones updated.
http://developers.arcgis.com/javascript/samples/find_map_datagrid/
        function showResults(results) {
          //This function works with an array of FindResult that the task returns
          map.graphics.clear();
    var symbol = new SimpleMarkerSymbol(
      SimpleMarkerSymbol.STYLE_CIRCLE,
      12,
      new SimpleLineSymbol(
     SimpleLineSymbol.STYLE_NULL,
     new Color([0, 0, 0, 0.9]),
      new Color([0, 0, 0, 0.5])
//----  Use this code if polygons ----///
//          var symbol = new SimpleFillSymbol(
//            SimpleFillSymbol.STYLE_SOLID,
//            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
//            new Color([98, 194, 204, 0.5])
I like zooming in using a button rather than zooming in on the row like this example..
http://developers.arcgis.com/javascript/samples/fl_zoomgrid/
However, I cannot get it to work.
The grid:
     <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid"  id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
      <thead>
        <tr>
              <th field="STOREID" formatter="makeZoomButton" width="40px">
                <img alt="+" src="assets/images/i_zoomin.png"  width="18" height="18"/>
              </th>
          <th field="STOREID" width="50px">ID</th>
          <th field="STORENO" width="70px">Store No</th>
          <th field="STORENAME" width="150px">Store Name</th>
          <th field="ADDRESS"  width="250px">Address</th>
          <th field="SALES" width="50px">Sales</th>
          <th field="GSF" width="50">GSF</th>
        </tr>
      </thead>
    </table>
    </div>
Here is the functions that it is calling.  makeZoomButton seems to be working okay but the zoomRow continues to get an Line: 190
Error: 'evt' is undefined.
        function zoomRow(id){
     var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).STOREID;
     var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
      return ((graphic.attributes) && graphic.attributes.STOREID === clickedTaxLotId);
     //CREATE THE POINT WITH THE SELECTED ROW
     var center2 = [selectedTaxLot[0].geometry.getLongitude(), selectedTaxLot[0].geometry.getLatitude()];
     //ZOOM LEVEL
     var zoom2 = 15;
     //CENTER AND ZOOM
     map.centerAndZoom(center2, zoom2);
Here is all of the code in case that helps make things clearer.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Display Find Task results in Dojo DataGrid</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dojox/grid/resources/claroGrid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
    <script src="http://js.arcgis.com/3.8/"></script>
 <style type="text/css">
.dojoxGrid table {
   margin: 0;
.dojoxGrid th, tr {
   font-size: 8pt;
</style>
    <script>
//Button for buffer (already in project)
   dojo.require("dojo.domReady!");
      dojo.require("esri.map");
   dojo.require("esri.layers.FeatureLayer");
      require([
        "esri/map",
        "esri/tasks/FindTask",
        "esri/tasks/FindParameters",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
  "esri/layers/FeatureLayer",
        "dojo/_base/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
        "dojo/data/ItemFileReadStore",
        "dijit/form/Button",
        "dojo/parser",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, FeatureLayer,
        Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser
        var findTask, findParams;
        var map, center, zoom;
        var grid, store;
        parser.parse();
        registry.byId("search").on("click", doFind);
        center = [-98.258, 38.236];
        zoom = 4;
        map = new esri.Map("map", {
          basemap: "streets",
          center: center,
          zoom: zoom
//var flMCY_Stores = new FeatureLayer("My Services", {
//          opacity:.01,
//          outFields: ["STORENAME" , "STOREID"]
//map.addLayer(flMCY_Stores);
        //Create Find Task using the URL of the map service to search
//        findTask = new FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer/");
        findTask = new FindTask("myservices");
        map.on("load", function () {
          //Create the find parameters
          findParams = new FindParameters();
          findParams.returnGeometry = true;
//          findParams.layerIds = [0];
//          findParams.searchFields = ["OWNERNME1", "OWNERNME2"];
          findParams.layerIds = [1];
          findParams.searchFields = ["STORENAME"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
        function doFind() {
          //Set the search text to the value in the box
          //findParams.searchText = dom.byId("ownerName").value;
    findParams.searchText = dom.byId("txtStoreName").value;
          findTask.execute(findParams, showResults);
      12,
          //create array of attributes
          var items = arrayUtils.map(results, function (result) {
            var graphic = result.feature;
            graphic.setSymbol(symbol);
            map.graphics.add(graphic);
            return result.feature.attributes;
          var data = {
            identifier : "STOREID", //This field needs to have unique values
            label : "STOREID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
            items : items
          //Create data store and bind to grid.
          store = new ItemFileReadStore({
            data : data
          var grid = registry.byId("grid");
          grid.setStore(store);
    grid.setSortIndex(3,"true");
    grid.on("rowclick", onRowClickHandler);
          //Zoom back to the initial map extent
          map.centerAndZoom(center, zoom);
//    function onRowClickHandler(evt) {
//     var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).STOREID;
//     var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
//      return ((graphic.attributes) && graphic.attributes.STOREID === clickedTaxLotId);
//     //CREATE THE POINT WITH THE SELECTED ROW
//     var center2 = [selectedTaxLot[0].geometry.getLongitude(), selectedTaxLot[0].geometry.getLatitude()];
//     //ZOOM LEVEL
//     var zoom2 = 15;
//     //CENTER AND ZOOM
//     map.centerAndZoom(center2, zoom2);
    function makeZoomButton(id){
        var zBtn = "<div data-dojo-type='dijit.form.Button'><img src='assets/images/i_zoomin.png'";
        zBtn = zBtn + " width='18' height='18'";
        zBtn = zBtn + " onClick=\"zoomRow('"+id+"')\"></div>";
        return zBtn;
     //ZOOM LEVEL
     var zoom2 = 15;
     //CENTER AND ZOOM
    </script>
  </head>
  <body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'"  style="width:100%;height:100%;margin:0;">
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="height:40px;">
      <p>Store name:
          <input type="text" id="txtStoreName" size="100px" value="Square" />
      </p>
      <p>  </p>
      <button id="search" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button" >Search
      </button>
    </div>
    <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;"></div>
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">
      <thead>
        <tr>
              </th>
        </tr>
      </thead>
    </table>
    </div>
  </div>
  </body>
</html>
JakeSkinner
Esri Esteemed Contributor
Hi Michael,
You will need to change the grid.on("rowclick", onRowClickHandler) to grid.on("rowclick", zoomRow).  Also, for the zoomRow function variable, set this to 'evt'.  I couldn't figure out how to show the zoom-in icon, but here is an example that works with a sample service.  It will zoom to the point feature when a row is clicked.
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
    </style>
.dojoxGrid table {
   margin: 0;
.dojoxGrid th, tr {
   font-size: 8pt;
</style>
<script>
      require([
        "esri/map",
        "dojo/_base/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/parser",
        "dojo/domReady!"
      ], function(
        var grid, store;
        parser.parse();
        zoom = 4;
          basemap: "streets",
          center: center,
          zoom: zoom
      var flMCY_Stores = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0", {
          outFields: ["*"]
      findTask = new FindTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer");
          findParams.searchFields = ["AREANAME"];
        function doFind() {
          var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 12,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL, new Color([0, 0, 0, 0.9]), 1), new Color([0, 0, 0, 0.5])
          var data = {
            identifier : "OBJECTID",
            label : "OBJECTID",
            items : items
            data : data
          grid.on("rowclick", zoomRow);
        var zBtn = "<div data-dojo-type='dijit.form.Button'><img src='images/zoom.png'";
        return zBtn;
      function zoomRow(evt){
          var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).OBJECTID;
            return ((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId);
          var zoom2 = 15;
</script>
  </head>
      <p>Store name:
          <input type="text" id="txtStoreName" size="100px" value="Dothan" />
      </p>
      <p>  </p>
      </button>
    </div>
      <thead>
        <tr>
              <th field="OBJECTID" formatter='makeZoomButton' width="40px">
                <img alt="+" src="images/zoom.png"  width="18" height="18"/>
              </th>
          <th field="OBJECTID" width="50px">ID</th>
          <th field="CLASS" width="70px">Store No</th>
          <th field="AREANAME" width="150px">Store Name</th>
          <th field="CAPITAL"  width="250px">Address</th>
          <th field="POP2000" width="50px">Sales</th>
          <th field="ST" width="50">GSF</th>
        </tr>
      </thead>
    </table>
    </div>
  </div>
  </body>
</html>
