DOH example?
1966
04-15-2012 12:56 PM
JohnCartwright
Hello All,
does anyone have an example they could share that uses Dojo's DOH test framework to test dijits which employ the ArcGIS API?
I'm a little confused about how to go about this when the base classes are hosted via CDN.  Is the downloadable API or SDK required?  Are the Dojo examples I see expect to find a local source folder for all of Dojo.
Thanks!
--john
derekswingley1
Great question�?? let me look into this and see if it's possible. I'll post back when I have more info.
derekswingley1
Hi John,
We put together a blog post and example on how to use DOH with the JS API:  http://blogs.esri.com/esri/arcgis/2012/05/21/writing-unit-tests-for-your-arcgis-api-for-javascript-a...
JohnCartwright
Hi John,
Thanks Derek, this is great - just what I was looking for!
--john
ryanmordoff
Is it possible to get an update on the blog post to work with the new 3.2 api and amd loading? It doesn't look as easy to get up and running with dojo 1.7.
