does anybody know what is the syntax of arcgis sql expression as i am finding difficult to understand and implemention .it will be much helpful.Thank you in advance
1248
07-12-2019 11:23 PM
AnupamSharma
i know the sql language,but i am unfamiliar with arcgis sql expression/syntax
RobertScheitlin__GISP
In ArcGIS you only have access to the WHERE clause of a SQL statement. Most SQL is supported as long as it is only the WHERE clause.
http://desktop.arcgis.com/en/arcmap/latest/map/working-with-layers/building-a-query-expression.htm
https://enterprise.arcgis.com/en/server/latest/administer/linux/about-standardized-queries.htm
AnupamSharma
https://developers.arcgis.com/javascript/latest/sample-code/layers-scenelayerview-query-stats/index....
in the above code why "when"  used also what is onStatisticField, outStatisticFieldName,statisticType it will be very much helpful if you explain.Thank you
Anupan,
  In that code snippit the when is part of an Arcade expression.
"CASE WHEN (yearCompleted >= '1975' AND yearCompleted <= '1999') THEN 1 ELSE 0 END",
https://developers.arcgis.com/javascript/3/jshelp/arcade.html
