Divide the entire map into Grids(rows and columns)
4882
03-04-2015 03:33 AM
HemaBahirwani
Hello all,
I am using arcgis devloper using Javascript. What would be the easiest way to divide the whole of the map in to rows and columns?
Tags (1)
KishorGhatage
I don't know how it would be done using code however in ArcMap FishNet would be helpful.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Hope it is helpful
Regards
Kishor
HemaBahirwani
Hi Kishor,
Thank you for your quick response. I had gone through this before, but this is for desktop application. But thank you so much.
