Displaying different featureLayers in the popup
931
07-15-2013 07:44 AM
RyanWhiley
I am currently running into an issue where when I select a featureLayer from the map, it will only give information on one of the featureLayers in a popup.  And when I select the other two featureLayers, the popup reads "No Feature Selected."  Below is code for the section I have been messing with trying to get the results I want, but so far nothing has worked.
function initSelectToolbar(results) {
        var operationalLayer = results[0,1,2].layer;
        var selectQuery = new esri.tasks.Query();
        dojo.connect(map, "onClick", function(evt) {
          selectQuery.geometry = evt.mapPoint;
          operationalLayer.selectFeatures(selectQuery, esri.layers.FeatureLayer.SELECTION_NEW, function(features) {
            if (features.length > 0) {
             //store the current feature
              updateFeature = features[0,1,2];
              map.infoWindow.setTitle(features[0,1,2].getLayer().name);
              map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
            } else {
              map.infoWindow.hide();
        dojo.connect(map.infoWindow, "onHide", function() {
          operationalLayer.clearSelection();
        var layerInfos = [{
          'featureLayer': operationalLayer,
          'showAttachments': true,
          'isEditable': true,
          'fieldInfos': [
            {'fieldName': 'adres', 'isEditable':true, 'tooltip': 'Adres', 'label':'Adres:'},
            {'fieldName': 'Buurten', 'isEditable':true, 'tooltip': 'idk', 'label':'Buurten'},
            {'fieldName': 'B_STATUS', 'isEditable':true,'label':'B_STATUS'},
            {'fieldName': 'FUNCTIE', 'isEditable':true, 'label':'FUNCTIE'},
            {'fieldName': 'Straatnaam_conc', 'isEditable':true, 'label':'Straatnaam'},
   {'fieldName': 'LENGTH', 'isEditable':true, 'tooltip': 'LENGTH', 'label':'Length:'},
            {'fieldName': 'WEGKLASSE', 'isEditable':true, 'tooltip': 'LOLOLOLOL', 'label':'WEGKLASSE'},
            {'fieldName': 'SHAPE_1_Length', 'isEditable':true,'label':'SHAPE_1_Length'},
            {'fieldName': 'Oneway', 'isEditable':true, 'label':'FUNCTIE'},
            {'fieldName': 'STRAATNAAM', 'isEditable':false, 'label':'Straatnaam'}
        var attInspector = new esri.dijit.AttributeInspector({
          layerInfos:layerInfos
        }, dojo.create("div"));
        //add a save button next to the delete button
        var saveButton = new dijit.form.Button({label:"Save","class":"saveButton"});
        dojo.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
        dojo.connect(saveButton,"onClick",function(){
           updateFeature.getLayer().applyEdits(null, [updateFeature], null);
        dojo.connect(attInspector, "onAttributeChange", function(feature,fieldName,newFieldValue) {
          //store the updates to apply when the save button is clicked
           updateFeature.attributes[fieldName] = newFieldValue;
        dojo.connect(attInspector,"onNext",function(feature){
          updateFeature = feature;
          console.log("Next " + updateFeature.attributes.OBJECTID);
        map.infoWindow.setContent(attInspector.domNode);
        map.infoWindow.resize(325, 220);
I have tried changing the layers but it does not seem to do anything helpful.
And I have operationalLayer defined in my init, but it is a global variable.  The link for it just references the basic FeatureServer page, without a link to a specific layer.  For example its just FeatureServer, not FeatureServer/0 or anything like that.  So what I am trying to do is have it so that when I select a feature, the information for that feature will display in the popup, no matter what feature it is.  Any advice that can be given would be greatly appreciated.
Thanks!
Ryan
