Disable Tooltip on Search Component
1605
12
05-20-2026 10:24 AM
SebastianKrings
there is a tooltip on the input which simply shows the previous placeholder/watermark.
Its gone, after typing any input.
I would like to disable this tooltip at all.
In case the locator is enabled as single source its gone and replaced by a locator message.
This shouldn't be disabled.
Seen on the sample here:
https://developers.arcgis.com/javascript/latest/references/map-components/components/arcgis-search/
BTW:
Why dont you put samples into the docs any more as we were used to have on the old widget docs.
To be honest, I often am googlin for the widgets doc to get the samples related and their codepens.
Hope this will come back for components as well.
Noah-Sager
Hi @SebastianKrings:
@SebastianKrings wrote:
1)
From our point of view a tooltip should not show te exact same information as e.g. a label or watermark. It then just duplicates the exactly same information.
How does this enhance accessibility?
Short digression: We customized actions in our apps in that way, that when they are only shown by icon, then a tooltip is activated. If there is enough space and next to the action the text enabled is set and shown, then the tooltip is deactived since it literally would show the same characters as the text already does.
I understand the confusion with duplicated information between a tooltip and a label or placeholder text. It sounds like that's the only case where you want the ability to remove a tooltip, and you do not have use cases for editing or adding tooltips. Do I have that correct?
SebastianKrings
Short: yes regarding search component
Long:
regarding the search component removing the tooltip is the only use case with duplicate text/use case.
Regarding search there is no use case to modify it.
On other ui components like calcite also, we already am showing different tooltips. But not regarding the search.
Noah-Sager
Great, thanks @SebastianKrings. I meant for any arcgis component, not just search, but we'll start with search and re-examine our tooltips story.
