Disable Map Navigation
1972
07-20-2011 07:57 AM
TimothyWilcoxon
I have this code in my html, if I select a zoom in button and then select the "select" button it will not disable the map navigation.
<button dojoType="dijit.form.Button" onClick="selectionToolbar.activate
(esri.toolbars.Draw.FREEHAND_POLYGON);map.disableMapNavigation();resetSums();">Select</button>
that is all i need right?
Thanks
Timothy
TimothyWilcoxon
Does the zoom in and zoom out have a seperate disable code?
Something like
map.disablezoomoutNav()?
JeffPace
that should be all you need, but if you created a navtoolbar, you might also need
this.navToolbar.deactivate();
Thanks
Timothy
