I tried to modify this example to disable the editing of geometry of existing features, but it doesn't work. Bug?
https://codepen.io/lkoumis1/pen/MWLZPyJ?editors=1000
const editor = new Editor({
view: view,
// Pass in the configurations created above
layerInfos: [{
layer:editConfigCrimeLayer,
geometryUpdatesEnabled: false
{layer:editConfigPoliceLayer,
Reference: https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Editor.html#layerInfos
Solved! Go to Solution.
No, the problem here is that those properties have been added in the wrong location. Instead, see lines 74, 88, and 125 below:
<html lang="en">
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title>Editor widget with configurations | Sample | ArcGIS Maps SDK for JavaScript 4.28</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.28/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.28/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require(["esri/WebMap", "esri/views/MapView", "esri/widgets/Editor"], function (
WebMap,
MapView,
Editor
let editConfigCrimeLayer, editConfigPoliceLayer;
// Create a map from the referenced webmap item id
let webmap = new WebMap({
portalItem: {
let view = new MapView({
container: "viewDiv",
map: webmap
view.when(() => {
// Create a custom group to separate the different areas of crime.
// This function takes a 'grouping' object which contains a feature template and a feature layer.
function customGroup(grouping) {
// If the layer is 'Police routes', do not group.
let groupHeading = "Police Routes";
if (grouping.layer.title.toLowerCase() === "crime map") {
switch (grouping.template.name) {
case "Criminal Homicide":
case "Rape":
case "Robbery":
case "Aggravated Assault":
groupHeading = "Violent Crime";
break;
case "Arson":
case "Burglary":
case "Larceny":
case "Motor Vehicle Theft":
groupHeading = "Property Crime";
break;
default:
groupHeading = "Quality of Life";
return groupHeading;
// Loop through the webmap's layers and set an edit configuration
view.map.layers.forEach((layer) => {
if (layer.title === "Police routes") {
editConfigPoliceLayer = {
layer: layer,
geometryUpdatesEnabled: false,
formTemplate: { //autocastable to FormTemplate
// Set it so that only one field displays within the form
elements: [{ // autocastable to FieldElement
type: "field",
fieldName: "PatrolType",
label: "Patrol Type"
} else {
// Specify a few of the fields to edit within the form
editConfigCrimeLayer = {
layer: layer,
formTemplate: { // autocastable to FormTemplate
type: "field",
fieldName: "fulladdr",
label: "Full Address"
type: "field",
fieldName: "neighborhood",
label: "Neighborhood"
type: "field",
fieldName: "ucrdesc",
label: "UCR Description"
type: "field",
fieldName: "crimecategory",
label: "Category"
type: "field",
fieldName: "casestatus",
label: "Status"
// Create the Editor
view: view,
layerInfos: [editConfigCrimeLayer, editConfigPoliceLayer],
// Override the default template behavior of the Editor widget
supportingWidgetDefaults: {
featureTemplates: {
groupBy: customGroup
// Add widget to the view
view.ui.add(editor, "top-right");
</script>
</head>
<body>
<div id="viewDiv"></div>
<div id="editorDiv"></div>
</body>
</html>
<html lang="en">
<head>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
WebMap,
MapView,
Editor
portalItem: {
map: webmap
view.when(() => {
case "Rape":
case "Robbery":
break;
case "Arson":
case "Burglary":
case "Larceny":
break;
default:
layer: layer,
type: "field",
} else {
layer: layer,
type: "field",
type: "field",
type: "field",
type: "field",
label: "Category"
type: "field",
label: "Status"
view: view,
featureTemplates: {
</script>
</head>
<body>
</body>
</html>
THank you. It works. I thought it was a bug based on the ESRI's example. But actually the code posted is missing some commas and it breaks the code.
