Directions widget doesn't work after log in without proxy
2690
10-11-2018 02:05 AM
ShakilChoudhury
I'm using the code here ArcGIS API for JavaScript Sandbox but with the proxy section removed. When loading the page I am prompted to login, after logging in the directions widget reads "There seems to have been an error.".
Tags (1)
RobertScheitlin__GISP
Shakil,
   When I remove the proxy and log in I am able to still get directions. I do get an error in the console about trying to access my org geocode service from developer.arcgis.com but that does not prevent the use of the directions widget.
ShakilChoudhury
Must be my environment then. I'm at work and most applications go through a proxy to reach the web. I have the proxy URL, how would I add it to the test app?
Shakil,
  Sorry I do not work with a corporate proxy so I don't have the answer to that.
