Dijit css location?
1119
11-02-2011 01:28 PM
NathanParis
I had to upgrade an old app that was using JS 1.5 to JS 2.5.  I pointed to the css to:
http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/soria/soria.css
There were a few issues with the old code, but also was some issue I just couldnt figure out why they werent working, when I realized the css above provided by esri doesnt even have some of the needed Dojo 1.6 styles.  For example .dijitOffScreen is not in the css.
So I point to http://ajax.googleapis.com/ajax/libs/dojo/1.6.0/dijit/themes/soria/soria.css
and everything works.
It doesn't matter which CDN I use, but seems like the esri one isn't even correct.  Is that one not suppose to be used?
derekswingley1
The version in the URL needs to be changed to the JS API version. Here's the one for 2.5:  http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/soria/soria.css
the dijitOffScreen class is defined in that file.
NathanParis
Thanks, was going of the old code.
