dijit.ColorPalette
1311
09-28-2012 02:33 PM
BanchanaPandey
I am trying to use a dijit.ColorPalette and I noticed that there is no more the onchange function that used to be there.
I am using javascript version 3.1.
How do you return the color selected from the dijit.ColorPalette object when there is no onchange method for it.
Thanks!
__Rich_
This one connects to the onChange event of the widget instance:
Okay, I noticed that if I did like this below, it works and the onChange event fires.
var myPalette = new dijit.ColorPalette({
                palette: "7x10",
                onChange: function (val) { alert(val); }
            }, "divColorPalette");
<div id="divColorPalette"></div>
This one connects to the onChange event of the div element:
But if i do like this, it won't work. I have tried changing onChange to onchange and still it doesn't fire if I declare like this below.
dojo.connect(divColorPalette, "onChange", function (val) {
            alert(val);
<div id="divColorPalette"  data-dojo-type="dijit.ColorPalette"></div>
In this case the onChange event:
a) doesn't exist
b) even if it did exist (!) isn't the same event
If you want to do it the second way i.e. using dojo.connect then you need to connect to the widget instance, not the DOM element.
Does that make sense?
(this might help - Writing Widgets#creating-extension-points)
BanchanaPandey
                palette: "7x10",
            alert(val);
Why it would work the first way and not the second?
so I just create a div tag and do not declare the div as dojo-data-type="dijit.ColorPalette"
__Rich_
                palette: "7x10",
            alert(val);
a) doesn't exist
