Difficulty Removing Underscores from Field in PopupTemplate
2286
03-01-2024 06:19 PM
Med-Karim-Rouissi
Hello ESRI Community,
I hope this message finds you well. I'm currently facing an issue with the JavaScript API for ArcGIS 4.24 while attempting to display the "Name_en" attribute in a PopupTemplate without underscores. Despite trying various approaches, the field's content is not being displayed as expected.
Here is a snippet of my current code:
let poptemp;
poptemp = new PopupTemplate({
    title: "{Name}",
    content: [{
        type: "fields",
        fieldInfos: [
                fieldName: "Name_ar",
                label: "Name_ar"
                fieldName: "Name_en".replace(/_/g, ''),
                label: "Name_en"
                fieldName: "Wiki_ar_link",
                label: "Wiki_ar_link"
                fieldName: "Wiki_en_link",
                label: "Wiki_en_link"
I have attempted to utilize the replace method to remove underscores in the "Name_en" field, but it doesn't seem to work as intended. I've also explored the use of expressionInfos without success.
If anyone has encountered a similar issue or has suggestions on how to correctly format the "Name_en" field within a PopupTemplate, I would greatly appreciate your insights.
Thank you in advance for your assistance!
Best regards,
Karim
MatthewDriscoll
You need to do this using arcade in the expressionInfos.
MatthewDriscoll
MatthewDriscoll
See this code pen for a working example.  It replaces "," with "  ZZZZ  '.
https://codepen.io/mbdriscoll/pen/gOyprmg
Med-Karim-Rouissi
Hi, thank you very much for your help on the Esri forum! Your suggestion really worked and I was able to resolve my issue. I really appreciate your time and expertise.
Here is my code:
let poptemp;
    title: "{Name}",
    content: [{
        type: "fields",
        fieldInfos: [
                label: "Name_ar"
                fieldName: "expression/Name_en",
                label: "Name_en",
    expressionInfos:[
                title: "Name_en",
                expression: "Replace($feature.Name_en, '_', '')",
Best,
Med-Karim Rouissi
Med-Karim-Rouissi
"One last question, the modules: "esri/popup/ExpressionInfo" and "esri/support/arcadeUtils", seem not to be necessary? They are not visible in your example, and in my code, their presence or absence doesn't make any difference. I simply have fewer errors in my console when I don't use them. The errors are non-blocking, and I am using the ArcGIS API for JavaScript 4.24 due to the requirements of my application."
