different Map behavior in 3.4 between "require" and AMD style loading
3036
10
04-02-2013 05:01 PM
JohnCartwright
Hello All,
I'm using v3.4 and finding some differences in the Map behavior when using the older "require" style module loading and the newer AMD style.  I'm using a BorderContainer with the map in the center panel and finding that w/ AMD, I have to explicitly call map.resize() to get it to fill the panel.  Also, w/ AMD the "center" property of a Map doesn't seem to have any effect. Listed below are two examples that I'd expected to provide identical results, but don't.  I assume it has something to do w/ the timing of the module load, but I'm not clear on what to do differently.
Thanks for any help!
--john
//works OK
function initMap() {
    map = new esri.Map("map", {
       basemap: "oceans",
       center: [-102, 40],
       zoom: 5
require(["esri/map"],
   function(Map) {
      var map = new Map("map", {
         basemap: "oceans",
         center: [-102, 40],  //does not seem to be respected
         zoom: 5});
   //not sure why this seems to be required w/ AMD loaded module
   map.resize();
derekswingley1
Jason,
Try this:  http://jsfiddle.net/NST5v/
Use dojo/ready to ensure that all modules have loaded and instead of parseOnLoad: true, manually call the parser.
More info on dojo/domReady vs. dojo/ready:  http://www.sitepen.com/blog/2013/04/17/dojodomready-vs-dojoready/
