Deterministic Map Crashing in Chrome
955
09-04-2025 09:41 AM
AddisonShaw
I'm noticing that with too many open tabs containing an ArcGIS map, all tabs of the same domain will crash at the same time. At first I thought it was something specific to our application (uses the JS SDK), but I'm able to reproduce using a sample map (i.e. https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=sketch)
Albeit, I think our application exacerbates the issue, with it I can only open ~10 tabs, each with their own map before they all crash. With the sample application I had to open ~27 tabs before they all crashed.
Each new instance of the sample application opens around 10 new threads under the same Chrome Renderer process. Wondering if this is expected behavior with either WebGL or the non-shared workers that the JS SDK spins up.
FWIW I'm running on an Apple M4 Pro with 48GB of RAM, Chrome version 139.0.7258.155
ShalakaPagay
I am unable to use the app after it is downloaded. Please help me as because of this problem I am unable to submit the assignment
AddisonShaw
Wrong thread?
