Determining if a tiled service is available
816
06-14-2010 02:24 PM
KevinGooss
I have a map that has the esri street map service within it. I also have additional lods outside of where the street map data is available (zoomed in further). When a user zooms past the lod where street data is available I would like to disable the button in my ui that shows/hides the street map. Is there a way to do this?
I basically need to compare the current zoom level and see if that is outside of the range of the street data and act accordingly.
Any suggestions?
JohnGrayson
Esri Alum
You could listen to the onExtentChange event of the map and then enable/disable your button based on the 'lod' parameter that is passed into this event.
